[OpenLayers-Users] Loading invisible layers
Nils Weinander nils.weinander at curalia.se
Wed Apr 2 09:40:31 EDT 2008
Christopher Schmidt wrote:
> On Wed, Apr 02, 2008 at 02:07:04PM +0200, Nils Weinander wrote:
>> I have noticed that layers (WMS in this case) are always
>> loaded, whether they are visible or not. Is there a way
>> to make a layer load (do the WMS request) first when a
>> layer's visibility is set to true?
> Are you using trunk/2.6, or 2.5? I think the answer is the latter, and
> if so, the answer is "Upgrade."
> If the answer is "The former", then the answer is "We thought the code
> did that: Please open a ticket for 2.7."
I'm using 2.5, thanks for the very quick response!
I don't think I'm in a position to upgrade right now,
but as I know that there is a solution, this shouldn't
be a major issue.
Nils Weinander  |  Systems Designer
Phone +46 (0)8 410 064 56
Mobile +46 (0)70 978 28 37
Curalia AB  |  www.curalia.se
Västmannagatan 15, 111 24 Stockholm, Sweden
