[OpenLayers-Users] Extensions on OpenLayers code
Linda Rawson
linda.rawson at gmail.com
Wed Apr 2 14:44:51 EDT 2008
Is that the right syntax?
On Wed, Apr 2, 2008 at 12:16 PM, Christopher Schmidt <
crschmidt at metacarta.com> wrote:
> On Wed, Apr 02, 2008 at 10:57:31AM -0600, Linda Rawson wrote:
> > I have several custom enhancements I have made to the source code. With
> the
> > onset of a new release I would like to put these in a separate file and
> > "override" the code that is in the release. For instance I might want
> to
> > add the following function, just an example, it might already be in
> there to
> > Map.js
> > getLayerByName: function(name) {
> > var foundLayer = null;
> > for (var i = 0; i < this.layers.length; i++) {
> > var layer = this.layers[i];
> > if (layer.name == name) {
> > foundLayer = layer;
> > return foundLayer;
> > Would I do something like the following in a .js file to be called after
> > Openlayers.js?
> > Map.prototype.getLayerByName=function(name) {
> > foundLayer = layer;
> > return foundLayer;
> Yes, this is what I would do.
> Regards,
> Christopher Schmidt
> MetaCarta
Linda Rawson
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20080402/155e5e9f/attachment.html
