[OpenLayers-Users] RC1 issue? with themes and styles
Bart van den Eijnden (OSGIS) bartvde at osgis.nl
Fri Apr 4 05:52:14 EDT 2008
Hi Stephen,
you can also try using !important in the stylesheet you want to prevail,
so you don't need to change the css class names, example:
.olXXX {
  width: 200px !important;
  height: 200px !important;
Best regards,
Bart
Stephen Woodbridge wrote:
> Christopher Schmidt wrote:
>>> OK, as a work around, if I change all occurrences
>>> olControlEditingToolbar   to   olControlMyEditingToolbar
>>> in my code and override style.css it displays the right thing. But I
>>> think some of the override theme stuff is broken 2.6rc1.
>> I've just checked: This code works exactly the same in 2.5. So
>> regardless of how broken it is, it does not appear to be a regression,
>> unless you can offer evidence otherwise.
>> (I downloaded broken.php, pointed the CSS to your files, and then
>> changed the OpenLayers file to reference 2.5 via /api/OpenLayers.js.)
> Christopher,
> Thank you for taking a look at this. I will accept your good judgement
> on this and try to dig into this a little more for my own education.
> The one thing I noticed while poking at this in FireBug and Inspecting
> the DOM, was that the missing icons had the CSS from the 2.6rc1
> style.css while all the others had the CSS applied from my override CSS.
> So by changing the CSS class to olControlMyEditingToolbar I seem to have
> avoided that conflict. I guess I'm not sure how the CSS rules get
> applied in this case when you have two stylesheets both with the same
> class names.
> Thank you again for your effort and assistance.
> -Steve
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
OSGIS, Open Source GIS
bartvde at osgis.nl
http://www.osgis.nl
