[OpenLayers-Users] FramedCloud popup autosizing with images
Christopher Schmidt crschmidt at metacarta.com
Fri Apr 4 11:59:38 EDT 2008
On Fri, Apr 04, 2008 at 04:32:32PM +0100, Xin wrote:
> Is it possible to have FramedCloud popups autosize with images without
> specifying img width/height?
No. A ticket is filed for 2.7: http://trac.openlayers.org/ticket/1469
This should have enough description to work with, I believe.
> The images I am using do not all have the same size. It would be great if it
> did autosize.
Sure.
> If not, is there a work around? Or any advice on how to change the existing
> code would also be appreciated.
Ticket above should help.
Regards,
Christopher Schmidt
MetaCarta
