[OpenLayers-Users] FramedCloud popup autosizing with images
Xin
xin at zenpow.com
Fri Apr 4 14:55:19 EDT 2008
Thanks Chaps.
Email preloading works like a dream. It's pretty easy to do for what I'm
doing.
On 04/04/2008, Erik Uzureau <euzuro at gmail.com> wrote:
> also note that if you preload the images, it should work.
> this may or may not be easy to do, but if you look at the
> examples/popupMatrix.html example,
> you will see that the four images it uses are preloaded (offscreen) in
> the body of the html
> erik
> On Fri, Apr 4, 2008 at 11:59 AM, Christopher Schmidt
> <crschmidt at metacarta.com> wrote:
> > On Fri, Apr 04, 2008 at 04:32:32PM +0100, Xin wrote:
> > > Is it possible to have FramedCloud popups autosize with images without
> > > specifying img width/height?
> > No. A ticket is filed for 2.7: http://trac.openlayers.org/ticket/1469
> > This should have enough description to work with, I believe.
> > > The images I am using do not all have the same size. It would be great
> if it
> > > did autosize.
> > Sure.
> > > If not, is there a work around? Or any advice on how to change the
> existing
> > > code would also be appreciated.
> > Ticket above should help.
> > Regards,
> > Christopher Schmidt
> > MetaCarta
> > Users mailing list
> > Users at openlayers.org
> > http://openlayers.org/mailman/listinfo/users
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20080404/50393945/attachment.html
