[OpenLayers-Users] Proportional Symbol Mapping
Bjorn Sandvik B.Sandvik at sms.ed.ac.uk
Sat Apr 5 16:51:09 EDT 2008
Correct url:
http://thematicmapping.org/experiments/openlayers/propsymbols2.html
Bjorn
Bjorn Sandvik wrote:
> Hi Arnd,
> Thank you for sharing this solution!
> It seems to work on:
> http://localhost/thematicmapping/experiments/openlayers/propsymbols2.html
> Do you think that this solution will have some performance issues due to
> more "complex" polygons?
> The good thing is that no event handling is needed when the user zoom
> the map.
> Bjorn
> Arnd Wippermann wrote:
>> Hi Bjorn,
>> Looking with interest at your map, I have a workaround. You can draw a
>> regular polygon with enough corners to look like a circle.
>> I have taken your code to test it. It seems to do what you want. It works
>> for OL 2.5 and 2.6, but with 2.6 the hover is broken.
>> <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN"
>> "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
>> <html xmlns="http://www.w3.org/1999/xhtml" xml:lang="en" lang="en">
>> <head>
>>   <title>Open Layers Example</title>
>>   <meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
>>   <style type="text/css">
>>     html, body { height: 100%; }
>>     body {
>>     margin:0px;
>>     background-color:white;
>>     overflow:hidden;
>>     font-family:Arial;
>>     #map {
>>       width: 100%;
>>       height: 100%;
>>    </style>
>>     <script src="OpenLayers_2.5_R4878_full_decimal.js"></script>
>> <!--    <script src="OpenLayers_2.6a_RC1.js"></script> -->
>>     <script type="text/javascript">
>>         var lon = 5;
>>         var lat = 40;
>>         var zoom = 3;
>>         var map, layer, vectors;
>>         function init(){
>>             var options = {
>>                 numZoomLevels: 6,
>>             map = new OpenLayers.Map( 'map', options );
>>             wms = new OpenLayers.Layer.WMS( "OpenLayers WMS",
>>                 "http://labs.metacarta.com/wms/vmap0?", {layers: 'basic'});
>>             naturalearth = new OpenLayers.Layer.TMS( "Natural Earth",
>> "http://thematicmapping.org/maptiles/", {layername: 'naturalearth',
>> serviceVersion: '.', type:'png'} );
>>             vectors  = new OpenLayers.Layer.Vector("N-Eck Layer");
>>             //vectors.setVisibility(false, true);
>>             map.addLayers([wms, naturalearth, vectors]);
>>             OpenLayers.loadURL("data/internet_users_2005_symbol.json", {},
>> null, onLoad, onLoadFailed);
>>             map.addControl(new OpenLayers.Control.LayerSwitcher());
>>             map.setCenter(new OpenLayers.LonLat(lon, lat), zoom);
>>             map.addControl(new OpenLayers.Control.MousePosition());
>>            var options = {
>>                hover: true,
>>                 onSelect: serialize
>>             var select = new OpenLayers.Control.SelectFeature(vectors,
>> options);
>>             map.addControl(select);
>>             select.activate();
>>             vectors.setVisibility(true, true);
>>         function onLoad(r) {
>>             if (r.status == 200) {
>>                 var parser = new OpenLayers.Format.GeoJSON();
>>                 var features = parser.read(r.responseText);
>>                 for (var i = 0; i < features.length; i++) {
>>                     var feature = features[i];
>>                     var value = feature.attributes['value'];
>>                     var name = feature.attributes['name'];
>>                     var pop = feature.attributes['population'];
>>                     //Openlayers.Geometry.Point
>>                     var origin = {};
>>                     origin.x = features[i].geometry.x;
>>                     origin.y = features[i].geometry.y;
>>                     var objF =
>> OpenLayers.Geometry.Polygon.createRegularPolygon(origin, (3 + (pop * (40 /
>> 1312978855)))/5.5, 25, 0);
>>                     //Erstelle feature
>>                     var theFeature = new
>> OpenLayers.Feature.Vector(objF,null,null);
>>                     theFeature.style = OpenLayers.Util.extend({},
>> OpenLayers.Feature.Vector.style['default']);
>>                     theFeature.style.fillOpacity = 0.9;
>>                     theFeature.style.fillColor =
>> feature.attributes['colour'];
>>                     theFeature.attributes['value']      = value;
>>                     theFeature.attributes['name']       = name;
>>                     theFeature.attributes['population'] = pop;
>>                     //add feature
>>                     vectors.addFeatures(theFeature);
>>                 vectors.renderer.clear();
>>                 vectors.moveTo(null, true); // Error in IE
>>                 features = null;
>>         function onLoadFailed(r) {
>>             //something went wrong
>>         function serialize() {
>>                 //code
>>                 var Msg = vectors.selectedFeatures[0].attributes["name"] + "
>>                 Msg    +=
>> vectors.selectedFeatures[0].attributes["population"] + " : ";
>>                 Msg    += vectors.selectedFeatures[0].attributes["value"];
>>                 document.getElementById("value").innerHTML = Msg;
>>     </script>
>>   </head>
>>   <body onload="init()">
>>     <div id="map"></div>
>>     <div id="value"
>> style="position:absolute;left:10px;bottom:10px;border:2px solid
>> #AAAAFF;padding:2px;background-color:#CCCCCC"></div>
>>   </body>
>> </html>
>> -----Ursprüngliche Nachricht-----
>> Von: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org] Im
>> Auftrag von Bjorn Sandvik
>> Gesendet: Donnerstag, 3. April 2008 23:05
>> An: users at openlayers.org
>> Betreff: [OpenLayers-Users] Proportional Symbol Mapping
>> Hi,
>> I'm currently testing the capabilities of doing thematic mapping with
>> OpenLayers.
>> This is a proportional symbol map based on GeoJSON encoded data:
>> http://thematicmapping.org/experiments/openlayers_propsymb.htm
>> My question: Is there a way to keep the relative size of the symbols when
>> the users zoom in/out?
>> (symbols should keep their size relative to the size of the countries).
>> Bjorn
>> http://blog.thematicmapping.org
>> The University of Edinburgh is a charitable body, registered in Scotland,
>> with registration number SC005336.
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
Scotland, with registration number SC005336.
