[OpenLayers-Users] geometry.getLength() returns what format
Pierre GIRAUD bluecarto at gmail.com
Tue Apr 8 09:29:42 EDT 2008
The reason why you were advised not to use this code in a production
environnement is probably because it comes from a sandbox.
As you probably already know, sandboxes are there to let developers
play with OpenLayers code and new features.
That said, the considered code may still need work, or may be based on
an old version of OpenLayers. It will therefore be somewhat difficult
to upgrade to a new OpenLayers version (2.6 when it will be out for
example) when you'll need to.
I think that there's no other constraints. And you're free to use this
code either way.
You just need to be aware of what precautions you'll have to follow.
For this particular feature (measuring tools), it would have been
easier if they were provided as an OpenLayers addin. But I'm pretty
sure that addins came after this code was initially written.
Regards,
Pierre
On Tue, Apr 8, 2008 at 8:28 AM, Pedro Simonetti
<pedrosimonetti at gmail.com> wrote:
>  I've mistyped the question. What I supposed to ask is:
>  What's the problem in using this IN a production environment? Does anybody
> has another better solution to point me out?
> Pedro Simonetti wrote:
>  > Dear Developers,
>  > I'm considering using the following code in an production environment, but
>  > I read in this thread, that this shouldn't be used in production
>  > environments, because isn't stable enought.
>  > I've researched about measure tools, and I saw many differents attempts of
>  > implementations, but this seems to be the most up-to-date one, as far as I
>  > can see.
>  > What's the problem in using this is a production environment? Does anybody
>  > regards,
>  > Pedro Simonetti.
>  > PS: Congratulations for this amazing project!
>  > Christopher Schmidt-4 wrote:
>  >> This measurement is in map units. If you want it in miles, you're going
>  >> to want to look at:
>  >> http://dev.openlayers.org/sandbox/tschaub/feature/examples/measure.html
>  >> http://dev.openlayers.org/sandbox/tschaub/feature/lib/OpenLayers/Control/Measure.js
>  View this message in context: http://www.nabble.com/geometry.getLength%28%29-returns-what-format-tp12508821p16547959.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
>  _______________________________________________
>  Users mailing list
>  Users at openlayers.org
>  http://openlayers.org/mailman/listinfo/users
