[OpenLayers-Users] TMS Layer origin and bounding box
Gérald Quintana
gerald.quintana at gmail.com
Tue Apr 8 10:14:52 EDT 2008
2008/4/8, Christopher Schmidt <crschmidt at metacarta.com>:
> Yeah, if you drop "projection":"" from that, it should work okay.
Yes it's better.
> Is your original image a worldwide map in EPSG:4326?
EPSG:4326: yes, worldwide: no :'(
> If not, it's likely that the answer is "You can't.",
> because OpenLayers doesn't support TMS
> with different maxExtent and so on (though there is a Summer of Code
> proposal to improve this.)
Thanks for the explanation, I was looking for a solution to improve
performance. I'll have to keep my WMS layer and search for
improvements on the GeoServer side.
Gerald
