[OpenLayers-Users] Javascript problem
Alexandre Gacon alexandre.gacon at gmail.com
Wed Apr 9 03:12:29 EDT 2008
Hello Pierre,
Your patch resolved my problem : now I can try to find why the pan is not
well handled for my layer.
Thank you !
Alexandre
On Tue, Apr 8, 2008 at 5:54 PM, Pierre GIRAUD <bluecarto at gmail.com> wrote:
> Can you try the patch attached to the ticket I just opened for this issue
> http://trac.openlayers.org/ticket/1502
> Regards,
> Pierre
> On Tue, Apr 8, 2008 at 5:32 PM, Pierre GIRAUD <bluecarto at gmail.com> wrote:
> > I took a quick look at your problem by trying to load the ViaMichelin
> >  API beside OpenLayers (in lite.html example).
> >  An error is raised in Events.js where OpenLayers tries to call push()
> >  on an array.
> >  But it seems that the ViaMichelin API modifies/extends the Array
> >  prototype to provide a new "ci" function (bad! bad!).
> >  This is a quick investigation and I have no workaround at the moment.
> >  Regards,
> >  Pierre
> >  On Tue, Apr 8, 2008 at 5:13 PM, Alexandre Gacon
> >  <alexandre.gacon at gmail.com> wrote:
> >  > Hello,
> >  > I am trying to develop a new Layer based on the service provided by
> >  > ViaMichelin. My problem is the following : as soon as I include the
> >  > reference to the JavaScript API of ViaMichelin (accessible via
> <script
> >  > src="http://api.viamichelin.com/apijs/js/api.js"></script>),
> OpenLayers does
> >  > not work anymore, even if I do not use my ViaMichelin Layer.
> >  > I took the google example and just added the script line : the google
> >  > example do not work anymore.
> >  > If anyone has an idea, it would be great.
> >  > Alexandre
> >  > _______________________________________________
> >  >  Users mailing list
> >  >  Users at openlayers.org
> >  >  http://openlayers.org/mailman/listinfo/users
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20080409/834cbed1/attachment.html
