[OpenLayers-Users] Busy Cursor
Linda Rawson linda.rawson at gmail.com
Wed Apr 9 11:36:08 EDT 2008
Thank you!
On Wed, Apr 9, 2008 at 5:48 AM, Bart van den Eijnden (OSGIS)
<bartvde at osgis.nl> wrote:
> Yes, it's not in the standard library, I am hoping it can be an addin soon.
> See also the Wiki:
> http://trac.openlayers.org/wiki/Addins/LoadingPanel
> You can add the following in a <script> tag after the OpenLayers.js <script>
> tag:
> http://dev.openlayers.org/sandbox/bartvde/loadingpanel/lib/OpenLayers/Control/LoadingPanel.js
> Or build your own OpenLayers.js. See also the Wiki page for details. You
> also need to use a bit of css to get the background-image. It's described in
> the Wiki page.
> Best regards,
> Bart
> OSGIS, Open Source GIS
> http://www.osgis.nl
> --------- Oorspronkelijk bericht --------
> Van: Carlos Pinto <cmspinto at gmail.com>
> Naar: Bart van den Eijnden OSGIS <bartvde at osgis.nl>
> Cc: Linda Rawson <linda.rawson at gmail.com>, OpenLayers Users
> <users at openlayers.org>
> Onderwerp: Re: [OpenLayers-Users] Busy Cursor
> Datum: 09/04/08 09:41
> > Hi all, I am using the library &quot;&lt;script&nbsp;
> src=&quot;http://www.openlayers.org/dev/lib/OpenLayers.js&quot;&gt;&lt;/script&gt;&quot;but
> I have seen this post and I thought that is really a good idea to put a
> loading panel but when I had the line:
> > map.addControl( new OpenLayers.Control.LoadingPanel({minSize: new
> OpenLayers.Size(600, 600)}) );the map don&#39;t appear!!!!!!Is it because of
> the openlayers version I am using?ThanksCarlos
> > On Wed, Apr 9, 2008 at 9:32 AM, Bart van den Eijnden (OSGIS)
> &lt;bartvde at osgis.nl&gt; wrote:
> > Hi Linda,
> > you could have a look at the LoadingPanel Control. Something similar could
> > be done to change the map cursor.
> > See:
> > http://trac.openlayers.org/ticket/102
> > and:
> http://trac.openlayers.org/browser/sandbox/bartvde/loadingpanel/lib/OpenLayers/Control/LoadingPanel.js
> > In maximizeControl you could set the busy mouse cursor on the map div, and
> > in minimizeControl change the cursor back.
> > example:
> http://dev.openlayers.org/sandbox/bartvde/loadingpanel/examples/loadingpanel.html
> > Best regards,
> > Bart
> > http://www.osgis.nl
> > Van: Linda Rawson &lt;linda.rawson at gmail.com&gt;
> > Naar: OpenLayers Users &lt;users at openlayers.org&gt;
> > Onderwerp: [OpenLayers-Users] Busy Cursor
> > Datum: 09/04/08 01:05
> > &gt; I have two layers that when I switch between them the performance is
> > &gt; so bad that there is a noticeable delay. &nbsp;How would I implement
> an
> > &gt; hourglass cursor to indicate to the user that the application is
> > &gt; working and then put the cursor back to normal when the layer is
> > &gt; loaded.
> > &gt;
> > &gt; --
> > &gt; Linda Rawson
> > &gt; _______________________________________________
> > &gt; Users mailing list
> > &gt; Users at openlayers.org
> > &gt; http://openlayers.org/mailman/listinfo/users
> > &gt;
> > &gt;
> > Users mailing list
Linda Rawson
