[OpenLayers-Users] Vector select styles
Bjorn Sandvik bjorn at thematicmapping.org
Wed Apr 9 16:16:41 EDT 2008
Thanks for your response. It works:
http://www.thematicmapping.org/experiments/openlayers/propsymbols.html
Bjorn
http://blog.thematicmapping.org
Christopher Schmidt wrote:
> On Wed, Apr 09, 2008 at 04:55:35PM +0100, Bjorn Sandvik wrote:
>> Hi,
>> I'm having a problem with hover styles using OpenLayers 2.6-rc1:
>> When you hover on of the circles the size is not preserved.
>> Is there a way to define the "default" and "select" styles to be the same?
> In 2.6-rc2, this is fixed.
> In 2.6-rc1, you can do:
> StyleMap({'default': style, 'select': style});
> If you want to only change (for example) the color, and not the size,
> you can do (in either version):
> StyleMap({'default': style, 'select': {strokeColor: '#0000ff'}});
> Regards,
