[OpenLayers-Users] Query Feature by Attribute and Zoom
Guillaume Sueur guillaume.sueur at neogeo-online.net
Thu Apr 10 17:05:57 EDT 2008
Maybe GeoDjango is a little bit oversized for this kind of thing ;-)
Basically, you just need to pull the extent of where you want to zoom to
on the client side and set the map extent with it.
By the way, you can even probably grab it from Geonames
(http://www.geonames.org/export/web-services.html#countryInfo)
Cheers,
Guillaume
Gregory Roby a écrit :
> Guillaume,
> Thanks for the quick response, this nudges me in a direction that will solve
> this (plus I can expand on it to solve a couple of other related issues I am
> sure I will have in the coming month or so).
> It sounds like the simplest way based on what I already have knowledge of
> then would be to:
> Create a HTML form in which a user enters the point.
> Create a CGI Python program that gets the proper zoom-to extent (maybe using
> GeoDjango, I have used Django a bit before).
> Dynamically output the new map webpage from the CGI program with the added
> Zoom to Extent Line.
> On rereading it, it sounds a bit different from what you suggested but the
> same basic idea...
> I will post back in a week or so the results (and hopefully some code) in
> case anyone is interested.
> Greg
> -----Original Message-----
> From: Guillaume Sueur [mailto:guillaume.sueur at neogeo-online.net]
> Sent: Thursday, April 10, 2008 3:48 PM
> To: groby
> Cc: users at openlayers.org
> Subject: Re: [OpenLayers-Users] Query Feature by Attribute and Zoom
> Hi Greg,
> As an WMS Server doesn't publish the features themselves, you will have
> to use another method for the requested functionnality, even if the
> layers can remain in WMS.
> 1. If you don't have so many countries, you can grab the extents of each
> of them manually and build a simple html select list with the extents in
> the value field. OnChange, you will fire a function getting the extent
> and setting your map extent with it.
> 2. If you have many countries, or if these data change often, you can
> build a simple web service sending you a stream (JSON for example) that
> you will use to build dynamically the same list as above. On the server
> side you can use many OpenSource tools to perform that : either
> php/mapscript, or even ogrinfo, in fact any tool that will be able to
> open your dataset and read the shapes in it. Of course, it's even
> simpler if they are stored into postGIS ;-)
> Hope that helps,
> Guillaume
> groby a écrit :
>> Hello,
>> I am fairly new to OpenLayers and GIS in general and new to this list.  I
>> have just setup an OpenLayers page.  I am using MapServer as my WMS Server
>> and my data is held in PostGIS tables.
>> I would like to know how can I create a way for a user to input text and
> to
>> zoom to the feature specified by the text.
>> An example of what I am trying to accomplish:
>> Take the Feature Info Example at
>> http://www.openlayers.org/dev/examples/getfeatureinfo.html.  If I wanted
> to
>> make it so a user could type in a country name then have the map zoom to
> the
>> extent of the country, how would I do so?  It needs to be a general enough
>> example I could use it with any text field (for example, a Serial Number).
>> I have found a few previous postings that seem to be asking a similar
>> question but not many answers.  Any pointers to a nice or ugly solution
> are
>> appreciated.
>> Thanks.
>> Greg
> The information contained in this electronic mail transmission is intended by Tri-County
> Electric Cooperative for the use of the named individual or entity to which it is directed
> and may contain information that is confidential or privileged.  If you have received this
> electronic mail transmission in error, please delete it from your system without copying or
> forwarding it, and notify the sender of the error by reply email so that the sender's address
> records can be corrected.
Guillaume SUEUR
Expert SIG et OpenSource
NEOGEO
46 RUE MATABIAU
31000 TOULOUSE
06 74 91 95 20
Site web : http://www.neogeo-online.net
