[OpenLayers-Users] Deactivate Draw-Control after feature added
Zac Spitzer zac.spitzer at gmail.com
Fri Apr 11 09:46:30 EDT 2008
I am only seeing this with OpenLayers.Handler.RegularPolygon which
seems to be exactly like
the other handlers in  to http://trac.openlayers.org/ticket/1143
this.layer has no properties
[Break on this error]  this.layer.renderer.clear();
RegularPolygon.js (line 365) (trunk)
whilst using a done callback, both featureAdded and done callbacks
throw an error
when deactivating a control ( also on 2.5)
z
On Fri, Apr 11, 2008 at 11:22 PM, Christopher Schmidt
<crschmidt at metacarta.com> wrote:
> On Fri, Apr 11, 2008 at 09:55:55PM +1000, Zac Spitzer wrote:
>  > I'm seeing the same issue with the trunk code at the moment, removing
>  > the deactivate from the
>  > featureAdded handler stops the error but i need a work around?
>  Did this work in 2.5? (Is it a regression?)
>  -- Chris
>  > any ideas?
>  > On Mon, Apr 7, 2008 at 6:13 PM, Kevin Kempfer <mail at kevinkempfer.de> wrote:
>  > > Hi,
>  > >  I'm trying to let the user draw a line feature and deactivate the draw
>  > > feature after the feature was added to the map. Here's my code:
>  > >  var drawControls = {
>  > >                 point: new OpenLayers.Control.DrawFeature(vectors,
>  > >                             OpenLayers.Handler.Point),
>  > >                 line: new OpenLayers.Control.DrawFeature(vectors,
>  > >  OpenLayers.Handler.Path,{featureAdded:
>  > > toggle }
>  > >                 rectangle: new OpenLayers.Control.DrawFeature(vectors,
>  > >                             OpenLayers.Handler.Box),
>  > >                 select: new OpenLayers.Control.SelectFeature(vectors),
>  > >             for(var key in drawControls) {
>  > >                 map.addControl(drawControls[key]);
>  > >  function toggle(feature){
>  > >         var linecontrol = drawControls['line'];
>  > >         linecontrol.deactivate();
>  > >  I get an error as soon as the control gets deactivated:
>  > >  this.point has no properties
>  > >  -> this.point.destroy();
>  > >  Here's the trace from FireBug:
>  > >  destroyFeature()Point.js (line 128)
>  > >  destroyFeature()Path.js (line 81)
>  > >  finalize()Point.js (line 139)
>  > >  dblclick(dblclick clientX=0, clientY=0)Path.js (line 240)
>  > >  triggerEvent("dblclick", dblclick clientX=0, clientY=0)Events.js (line 612)
>  > >  handleBrowserEvent(dblclick clientX=0, clientY=0)Events.js (line 640)
>  > >  bindAsEventListener(dblclick clientX=0, clientY=0)
>  > >  Looks like the control gets deactivated too early in the feature-adding
>  > > process. Is there any advice on how to deactivate a draw control after
>  > > drawing a feature?
>  > >  Thanks,
>  > >  Kevin
>  > > _______________________________________________
>  > >  Users mailing list
>  > >  Users at openlayers.org
>  > >  http://openlayers.org/mailman/listinfo/users
>  > Zac Spitzer -
>  > http://zacster.blogspot.com (My Blog)
>  > +61 405 847 168
>  > Users mailing list
>  Christopher Schmidt
>  MetaCarta
Zac Spitzer -
+61 405 847 168
