[OpenLayers-Users] (Openlayers + Mapserver) not able to dispaly Raster image.
Christopher Schmidt crschmidt at metacarta.com
Tue Apr 15 15:58:54 EDT 2008
On Tue, Apr 15, 2008 at 12:48:43PM -0700, ptang83 at yahoo.com wrote:
> I used Mapserver + Openlayers. I can load shp data and display it (The image displayed in openlayer is small). However, somehow I am not able to display any raster map even. I only see a blank rectangular on my web browzer.  I can use shp2img utility to generate this image. It just didn't display in the openlayer.
"Causing a URL to return content you want is the responsibility of other
software. Causing OpenLayers to load that URL is the responsibility of
OpenLayers."
http://trac.openlayers.org/wiki/TroubleshootingTips#Problemswithimagesbeingincorrect
> Thanks in advance..
> I have downloaded ms4w Mapserver and has the following config.
> # Apache 2.2.8
> # PHP 5.2.5
> # mapserv 5.0.2 at /cgi-bin/mapserv.exe
> LOG files show nothing wrong:
> Sun Apr 13 21:57:14 2008,12804,127.0.0.1,nitelti020l,3,-0.000000 -90.000000 180.000000 90.000000,-1.000000 -1.000000,,normal execution
> Sun Apr 13 21:57:14 2008,14076,127.0.0.1,nitelti020l,3,-180.000000 -90.000000 0.000000 90.000000,-1.000000 -1.000000,,normal execution
> MAP file:
> # Map file created from QGIS project file C:/Program Files/Quantum GIS/nitelti020l.qgs
> # Edit this file to customize for your map interface
> MAP
>   NAME nitelti020l
>   # Map image size
>   SIZE 600 600
>   UNITS dd
>   EXTENT -6086744.000000 -5878356.737659 4278894.138000 7580130.593659
>   PROJECTION
>    'proj=longlat'
>    'ellps=WGS84'
>    'datum=WGS84'
>    'no_defs'
>   END
>   # Background color for the map canvas -- change as desired
>   IMAGECOLOR 192 192 192
>   IMAGEQUALITY 95
>   IMAGETYPE jpeg
>   OUTPUTFORMAT
>     NAME jpeg
>     DRIVER 'GD/JPEG'
>     MIMETYPE 'image/jpeg'
>     #IMAGEMODE PC256
>     EXTENSION 'jpeg'
>   END
>   # Legend
>   LEGEND
>       IMAGECOLOR 255 255 255
>     STATUS ON
>     KEYSIZE 18 12
>     LABEL
>       TYPE BITMAP
>       SIZE MEDIUM
>       COLOR 0 0 89
>     END
>   END
>   # Web interface definition. Only the template parameter
>   # is required to display a map. See MapServer documentation
>   WEB
>     # Set IMAGEPATH to the path where MapServer should
>     # write its output.
>     IMAGEPATH '/tmp/'
>     # Set IMAGEURL to the url that points to IMAGEPATH
>     # as defined in your web server configuration
>     IMAGEURL '/tmp/'
>     # WMS server settings
>     METADATA
>       'wms_title'           'nitelti020l'
>       'wms_onlineresource'  'http://localhost/cgi-bin/mapserv?map=wms.map&'
>       'wms_srs'             'EPSG:4326'
>     END
>     #Scale range at which web interface will operate
>     # Template and header/footer settings
>     # Only the template parameter is required to display a map. See MapServer documentation
>   END
>   WEB
>     LOG "c:\tmp\mapserv.log"
>   END
>   LAYER
>     NAME 'nitelti020l'
>     TYPE RASTER
>     DATA 'C:\oatdir\nitelti020l.tar\nitelti020l.tif'
>     METADATA
>     END
>     STATUS DEFAULT
>     TRANSPARENCY 100
>     PROJECTION
> #    'proj=longlat'
> #    'ellps=WGS84'
> #    'datum=WGS84'
> #    'no_defs'
> "init=epsg:4326"
>     END
>   END
> END
> Raster date download
> http://edcftp.cr.usgs.gov/pub/data/nationalatlas/nitelti020l.tar.gz
> simple open layer code
> <html xmlns="http://www.w3.org/1999/xhtml">
>   <head>
>     <style type="text/css">
>         #map {
>             width: 800px;
>             height: 475px;
>             border: 1px solid black;
>     </style>
>     <script src="http://openlayers.org/dev/lib/OpenLayers.js"></script>
>     <script type="text/javascript">
>         var map, layer;
>         function init(){
>             map = new OpenLayers.Map( 'map' );
>             layer = new OpenLayers.Layer.MapServer( "OpenLayers WMS",
>                     "http://localhost/cgi-bin/mapserv.exe", {map: 'C:/Program Files/ms4w/Apache/htdocs/nitelti020l.map'} );
>             map.addLayer(layer);
>             map.zoomToMaxExtent();
>     </script>
>   </head>
>   <body onload="init()">
>     <div id="map"></div>
>   </body>
> </html>
>       ____________________________________________________________________________________
> Be a better friend, newshound, and
> know-it-all with Yahoo! Mobile.  Try it now.  http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
Christopher Schmidt
MetaCarta
