[OpenLayers-Users] Maximum extent shrinks when zooming in
zenzero-2001
John.Westwood at port.ac.uk
Tue Apr 15 18:00:28 EDT 2008
Hi Christopher,
That's interesting that's it's not considered a bug. Personally, I would
definitely think of it as a bug or possibly an undocumented feature :) I
hope you don't think that I was complaining, I think that OpenLayers is
great.
I think I have found a solution to the problem: Use the restrictedExtent
keyword, I think that will do the trick. :)
Keep up the good work and I look forward to v2.6
zenzero-2001
Christopher Schmidt-4 wrote:
> On Tue, Apr 15, 2008 at 12:59:53PM -0700, zenzero-2001 wrote:
>> I checked the zoomLevels example that comes with OpenLayers and this
>> suffers
>> from the same problem. So I guess that this means it is a bug in
>> OpenLayers.
>> Any idea when it may be fixed?
>>I don't consider anything you've thus far described a bug, so as far as
>>I know, there is no plan to change it.
View this message in context: http://www.nabble.com/Maximum-extent-shrinks-when-zooming-in-tp16699035p16711909.html
