[OpenLayers-Users] Openlayers displa.. size of the map very
small.
ptang83 at yahoo.com
Tue Apr 15 18:23:08 EDT 2008
I used the same Map file for the following scenario:
1. using mapserver utility "shp2img" and it generated a 800x500 image (Good size).
2. mapscript + mapserver and it generated a 800x500 image (Good size)
3. openlayer + mapserver and no display.
4. If I change "proj=lcc" to "proj=latlong". openlayer + mapserver generate a 256x256 small image.
Does this mean openlayers can't handle mapfile "proj=lcc"?
Is there a place in openlayer code I can make mapserver generate a 800x500 image if I used "proj=latlong"?
Thanks!
--- On Tue, 4/15/08, David Fawcett <david.fawcett at gmail.com> wrote:
> From: David Fawcett <david.fawcett at gmail.com>
> Subject: Re: [OpenLayers-Users] Openlayers displa.. size of the map very small.
> To: ptang83 at yahoo.com
> Cc: users at openlayers.org
> Date: Tuesday, April 15, 2008, 3:52 PM
> Take a look at these 5 lines from your map file:
> EXTENT -8000000 300000 5000000 1500000
> UNITS METERS
> PROJECTION
> "proj=lcc"
> "lat_1=32" "lat_2=44"
> "lat_0=38" "lon_0=-100"
> "x_0=0" "y_0=0" "ellps=GRS80"
> "datum=NAD83"
> END
> You are telling MapServer that your image extent is 13
> million degrees in
> the x direction.
> Your EXTENT and UNITS need to be of the same units as your
> output
> projection.
> Try UNITS "dd" and convert your extent to
> degrees.
> David.
> On Tue, Apr 15, 2008 at 3:06 PM, <ptang83 at yahoo.com>
> wrote:
> > I downloaded a demo which display a nice map through
> mapserver. The image
> > is like this.
> > http://www.mobilegeographics.com/mapserver/usa1.phtml
> > The image is big and nice.
> > When I changed it to display throught openlayers. The
> openlayer map only
> > display a blank windows with all controls. If I change
> the "proj=lcc" to
> > "proj=latlong" , then it display a map but
> the size of the map is very small
> > and only occupied the upper lift corner of the
> openlayers div. Is there any
> > way to make display fit the windows?
> > Would like to take any suggestion. Thanks in advance!
> > usa1.html
> > <html
> xmlns="http://www.w3.org/1999/xhtml">
> > <head>
> > // <title>My Test MapServer
> Layer</title>
> > <style type="text/css">
> > #map {
> > width: 800px;
> > height: 500px;
> > border: 1px solid black;
> > </style>
> > <script type="text/javascript"
> src="
> http://clients.multimap.com/API/maps/1.1/metacarta_04"></script>
> > <script
> src="http://openlayers.org/dev/lib/OpenLayers.js"></script>
> > <script type="text/javascript">
> > var map, layer;
> > function init(){
> > map = new OpenLayers.Map( 'map' );
> > layer = new OpenLayers.Layer.MapServer(
> "OpenLayers WMS",
> "http://localhost/cgi-bin/mapserv.exe",
> > {map: 'C:/Program
> > Files/ms4w/Apache/htdocs/MSrecipes/usa1.map'} );
> > // {map: 'C:/Program
> > Files/ms4w/Apache/htdocs/usa1.map'} );
> > map.addLayer(layer);
> > map.zoomToMaxExtent();
> > </script>
> > </head>
> > <body onload="init()">
> > <div id="map"></div>
> > </body>
> > </html>
> > map file
> > MAP
> > NAME USA1
> > STATUS ON
> > SIZE 800 500
> > IMAGETYPE PNG
> > IMAGECOLOR 240 240 240
> > SHAPEPATH
> "C:\oatdir\statesp020.tar"
> > UNITS METERS
> > PROJECTION
> > "proj=lcc"
> "lat_0=38"
> > "lon_0=-100" "x_0=0"
> "datum=NAD83"
> > END
> > WEB
> > IMAGEPATH "C:\Program
> Files\ms4w\Apache\htdocs\tmp\"
> > IMAGEURL "/tmp/"
> > END
> > LAYER
> > NAME "US state boundaries"
> > TYPE POLYGON
> > STATUS DEFAULT
> > DATA
> 'C:\oatdir\statesp020.tar\statesp020'
> > PROJECTION
> > "proj=latlong"
> > "ellps=GRS80"
> > "datum=NAD83"
> > END
> > CLASS
> > NAME "US states"
> > OUTLINECOLOR 60 60 60
> > COLOR 255 255 0
> > SYMBOL 0
> > END
> > END
> > END
> ____________________________________________________________________________________
> > Be a better friend, newshound, and
> > know-it-all with Yahoo! Mobile. Try it now.
> http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
> > Users mailing list
> > Users at openlayers.org
> > http://openlayers.org/mailman/listinfo/users
know-it-all with Yahoo! Mobile. Try it now. http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
