[OpenLayers-Users] popups for markers dynamically generated
from KML
Mike Quentel
mquentel at rim.com
Wed Apr 16 11:01:58 EDT 2008
For now, it looks like this:
function mousedown(evt) {
alert(marker.lonlat);
Not sure how to pass the specifically bound marker object to the
function.
Mike
-----Original Message-----
From: Christopher Schmidt [mailto:crschmidt at metacarta.com]
Sent: Wednesday, 16 April 2008 10:55
To: Mike Quentel
Cc: users at openlayers.org
Subject: Re: [OpenLayers-Users] popups for markers dynamically generated
from KML
On Wed, Apr 16, 2008 at 10:40:32AM -0400, Mike Quentel wrote:
> marker.events.register("mousedown", marker, mousedown);
This isn't the useful part of the code. The part of the code that
matters is what is *in* the mousedown function. My guess is that it
refers to a variable ('marker') rather than the bound marker object
('this'), but there's no really any way of knowing with the code you've
provided.
Regards,
Christopher Schmidt
MetaCarta
This transmission (including any attachments) may contain confidential information, privileged material (including material protected by the solicitor-client or other applicable privileges), or constitute non-public information. Any use of this information by anyone other than the intended recipient is prohibited. If you have received this transmission in error, please immediately reply to the sender and delete this information from your system. Use, dissemination, distribution, or reproduction of this transmission by unintended recipients is not authorized and may be unlawful.
