[OpenLayers-Users] Vectors on the move
bradleyspencer
brad at cubewerx.com.au
Thu Apr 17 00:10:51 EDT 2008
I am creating a selection box with a Shift-Mouse control and using this as a
BBox criteria to do a getfeatureInfo request. That works just fine. I also
draw the box on a vector layer and that is fine as well.
However, when you pan up and down the select box floats relative to the
base map. Has anyone seen this and if so is there a workaround?
If this is new I will make a little test app.
Cheers,
Brad Spencer
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20080417/d269d07f/attachment.html
