[OpenLayers-Users] OpenLayers 2.6 tileloaded event
Emily Gouge egouge at refractions.net
Fri Apr 18 13:14:47 EDT 2008
This workaround worked great.  Thanks for the help.
Christopher Schmidt wrote:
> On Thu, Apr 17, 2008 at 08:54:06AM -0700, Emily Gouge wrote:
>> Previously we were using the tileloaded event to inform users of how
>> many tiles were remaining to be loaded.  Has this event changed in
>> OpenLayers 2.6?  Is there some other event or method I should be using
>> to provide a similar status to users?
> This is a bug/regression, created by
> http://trac.openlayers.org/changeset/6832/trunk/openlayers/lib/OpenLayers/Events.js .
> While we work out the correct resolution to this issue, you can use the
> following workaround:
> Pass an "EVENT_TYPES" property to Layer options, as such:
>     buffer = new OpenLayers.Layer.WMS( "WMS Buffer 0",
>             "http://labs.metacarta.com/wms/vmap0",
>             {layers: 'basic'} ,
>             {EVENT_TYPES:["loadstart", "loadend", "loadcancel",
>                           "visibilitychanged","tileloaded"]}
> Note the inclusion of the 'tileloaded' event.
> I'm sorry about this regression.
> Regards,
