[OpenLayers-Users] Fwd: Custom Box handler conflict?
Diego Guidi
diegoguidi at gmail.com
Mon Apr 21 12:30:26 EDT 2008
I retry to make the same questions... sorry for the "spam" but I hope
to get some suggests on how to fix my problem
---------- Forwarded message ----------
Date: Wed, Apr 16, 2008 at 11:03 AM
Subject: Custom Box handler conflict?
To: OpenLayers Users <users at openlayers.org>
I'm using the brand new 2.6 (well done guys!) but I haven't try with
older versions, so...
In my website I'm using OpenLayers and NavToolBar component, that
implements a ZoomBox handler for a zoom rect funtion that works well.
I've tried to add this custom components, taken from the openlayers
samples, and i have a strange behavior:
var customBox = new OpenLayers.Control();
OpenLayers.Util.extend(customBox,
draw: function ()
this.box = new OpenLayers.Handler.Box(customBox,
{ "done": this.notice },
{ keyMask: OpenLayers.Handler.MOD_SHIFT });
this.box.activate();
notice: function (bounds)
var ll = map.getLonLatFromPixel(new
OpenLayers.Pixel(bounds.left, bounds.bottom));
var ur = map.getLonLatFromPixel(new
OpenLayers.Pixel(bounds.right, bounds.top));
alert(ll.lon.toFixed(4) + ", " +
ll.lat.toFixed(4) + ", " +
ur.lon.toFixed(4) + ", " +
ur.lat.toFixed(4));
If i add this component to the map, when i try the code all works well:
the navtoolbar is in "pan" state so i could pan the map as usual, and
using shift i could drag a zoombox and show the bounding box
coordinates.
If i select the zoomrect tool from navtoolbar i lost the behavior of
the custom component :(
Any try to use shift + zoombox generates the behavior of the zoomrect tool.
any suggestion?
Diego Guidi
http://lacorrente.blogspot.com
