[OpenLayers-Users] multiple epsg coordinates display
Alessio Di Lorenzo alessio.dilorenzo at gmail.com
Wed Apr 23 08:08:11 EDT 2008
as explained I need to show the MousePosition coordinates values in epsg
4326 even if my map is in epsg 32633.
Well, this topic seems aswer my needs.
http://www.nabble.com/How-to-change-displayProjection-for-MousePosition-Control-td16331163.html#a16340730
So, I tried to do the following:
1) First, I downloaded proj4js from svn and I added it in my page's header
<script src="OpenLayers-2.6/OpenLayers.js" type="text/javascript"></script>
<script scr="proj4js/lib/proj4js.js" type="text/javascript"></script>
<script scr="proj4js/lib/defs/EPSG32633.js" type="text/javascript"></script>
<script scr="proj4js/lib/defs/EPSG4326.js" type="text/javascript"></script>
the EPSG32633.js and EPSG4326.js files (not included in the downloaded
package) contains, respectively, these strings:
Proj4js.defs["EPSG:32633"] = "+proj=utm +zone=33 +ellps=WGS84 +datum=WGS84 +units=m +no_defs ";
Proj4js.defs["EPSG:4326"] = "+proj=longlat +ellps=WGS84 +datum=WGS84 +no_defs ";
2) Then I added this code to my page
mp = new OpenLayers.Control.MousePosition();
	mp.displayProjection = new OpenLayers.Projection("EPSG:4326");
	map.addControl(mp);
but the displayed coordinates are always 32633...
may you help me to understand the problem?
thx, alessio
