[OpenLayers-Users] multiple epsg coordinates display
Mike Adair madair at dmsolutions.ca
Thu Apr 24 10:02:20 EDT 2008
Note that you can also load the file lib/proj4js-compressed.js which
includes all files required (or lib/proj4js-combined.js if you want to
debug) and the libPath setting is not used.
Mike
Alessio Di Lorenzo wrote:
> Hi list,
> with the precious suggestions of Giovanni Allegri I solved this issue!
> There where two problems:
> 1) there were typos (as Chris said) in my code: various "scr" instead
> "src" linking the js scripts in the header... ahhaarg
> 2) it is mandatory to set Proj4js.libPath='proj4js/lib/'; in the init
> function to access to projCode/utm.js, that is needed to interpret UTM EPSGs
> Hope this will be helpful for someone in future,
> alessio
> Alessio Di Lorenzo ha scritto:
>> Hello,
>> by reading on the web I noticed that what I want to do is possible
>> through proj4js library
>> "Support for reprojecting user-facing controls like mouseposition"
>> Cuold someone show me any examples?
>>> Hi list,
>>> I have a little OL application showing data in utm33-wgs84 (epsg:
>>> 32633) and I'm using a separate div to display the mouse position in
>>> 32633 with no problems.
>>> What I'd like to do is to display the mouse position also in
>>> geographical wgs84 (epsg: 4326) in another different div.
>>> In this way users could see both 32633 and 4326 coordinates at the
>>> same time.
>>> Is it possible?
>>> thx
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
