[OpenLayers-Users] CloudAmber drop shadow
Fred warnock fred.warnock at gmail.com
Wed Apr 30 13:41:39 EDT 2008
Erik,
It was always our intention to submit this back to the community in the
way you have described.
I just wanted to get some feedback on our approach before standing it up
as a "solution".  It seems that the code was set up to be configurable,
kind of like a style sheet, but in Javascript.  We adjusted the
positioning and sizing values, following what patterns we could recognise.
Once we've filed the ticket, I'm sure we'll get that feedback so we can
tidy it up if need be.
fred
Erik Uzureau wrote:
> This is unfortunately the very gap that keeps most of the good work that people
> do in the community from getting re-absorbed into the project.
> It is unusual that folks have the time or resources to develop
> *general* solutions
> to problems they encounter when using OL (or any other FOSS project, I would
> venture to say). The goal is generally solving the task at hand rather
> than forming
> a universal solution that might be helpful to others.
> And that, of course, is nobody's fault. The only way to overcome it is
> to convince
> our managers that a little extra effort to give things back to the
> community is a
> worthwhile proposition: no simple task, indeed.
> Just taking the step you did to write to the mailing list with your
> work is more than
> most people do and a great help as it is. If you could spend the time
> to get your
> work into a ticket in trac with a straightforward patch, it would be
> even better... but
> as I've said above, even just the email to the list is a generous gesture.
> -e
> On Wed, Apr 30, 2008 at 10:01 AM, Fred warnock <fred.warnock at gmail.com> wrote:
>> Thanks guys,
>> Bill is going to follow up on your suggestion.
>> I initially thought sending it to this list would allow some folks to
>> comment on what we did before putting it forward as a "solution".  It works
>> for our needs, but poking around with the numbers to get the image with a
>> drop shadow to work left us feeling a bit uneasy.
>> We were not sure that we changed the numbers as optimally as possible, even
>> though visually it works.
>> All the best,
>> Fred
>> Erik Uzureau wrote:
>>> On Tue, Apr 29, 2008 at 9:21 PM, Roald de Wit <roald.dewit at lisasoft.com>
>> wrote:
>>>> Hi Fred,
>>>> On Mon, 2008-04-28 at 10:00 -0400, Fred warnock wrote:
>>>>> Last week Bill Bronsema and I updated to the latest version and found
>>>>> that the drop shadow was no longer part of the out-of-the-box
>> CloudAmber
>>>>> popup.  So we made a 24 bit PNG that was close to the old style and
>>>> Thanks for that. In order to have your contribution added to OpenLayers,
>>>> it is best that you create a ticket in Trac and add this as a feature
>>>> [1]. Create a patch against the current OL version (2.6) or even better:
>>>> trunk. You can attach the image to the ticket.
>>>> Solutions provided on the mailing list get easily forgotten, which would
>>>> be a pity.
>>> It is true. It is a constant and ongoing pity. :-(
>>> Erik
>>>> Regards,
>>>> Roald
>>>> [1] http://trac.openlayers.org/wiki/HowToContribute
>>>> Roald de Wit
>>>> Software Engineer
>>>> Commercial Support for Open Source GIS Software
>>>> http://lisasoft.com/LISAsoft/SupportedProducts/
>>>> _______________________________________________
>>>> Users mailing list
>>>> Users at openlayers.org
>>>> http://openlayers.org/mailman/listinfo/users
