[OpenLayers-Users] wfs stylemap example?
Alexandre Dube adube at mapgears.com
Fri Aug 1 08:59:33 EDT 2008
It worked for me, thanks Arnd.
I used this :
OpenLayers.Feature.Vector.style['default']['cursor'] = 'crosshair';
Try 'default' instead of 'select'
Alexandre
Arnd Wippermann wrote:
> Instead of "select" try "crosshair".
> I init my cursor for select with
> OpenLayers.Feature.Vector.style['select']['cursor'] = 'crosshair';, but it
> doesn't work. But when i select and then unselect a feature, then the cursor
> will change, when I hover over the feature.
> Perhaps it is bug. When I look in my application at the generated svg in
> firebug, there is no attribute "cursor". But after a select the attribute is
> added.
> Arnd Wippermann
> -----Ursprüngliche Nachricht-----
> Von: adube at mapgears.com [mailto:adube at mapgears.com]
> Gesendet: Donnerstag, 31. Juli 2008 15:44
> An: Christopher Schmidt
> Cc: Arnd Wippermann; users at openlayers.org
> Betreff: Re: [OpenLayers-Users] wfs stylemap example?
> Christopher Schmidt wrote:
>> Alternatively, set your strokeWidth to a larger number (I always use 3).
> Wow !  Haven't though about that but it's a simple and clever solution
> :)  Thanks.
>> You can't change the color when hovering, but you can change the cursor:
>> set OpenLaeyrs.Feature.Vector['default'].cursor = "select"; and it
>> will change the cursor when it is over a feature.
> I think it's more like :
> OpenLayers.Feature.Vector.style['default'].cursor = "select";  but it's not
> working.  The value "" of the cursor IS changed to "select", but that does
> nothing when my mouse is over a feature.
> In OpenLayers.Features, I have Vector and WFS.  I assumed that because my
> layer is WFS I had to change my cursor there but it has no style.
> Any ideas ?
>> No real way to do that with the current code. Specifically, the reason
>> is becasue the event is determined based on the browser saying "Here
>> is the element that was under the mouse when the event triggered." But
>> making the feature bigger will help.
> I will try to think of something.
> Alexandre Dubé
> Mapgears
> www.mapgears.com
Alexandre Dubé
Mapgears
www.mapgears.com
