[OpenLayers-Users] Contains polygon function
Tim Schaub tschaub at opengeo.org
Mon Aug 4 08:00:28 EDT 2008
Hey-
Bas Couwenberg wrote:
> Hello,
> is there an function in OpenLayers that checks if a polygon contains
> another polygon? I saw there is one for points and I also found a mail
> about this matter:
> http://www.nabble.com/OpenLayers.Geometry.Polygon---to16179019.html#a16179019.
The geometry intersection code includes most of the logic you need to do
this.
http://trac.openlayers.org/browser/trunk/openlayers/lib/OpenLayers/Geometry/Polygon.js#L144
This could be separated out as a contains method for polygons.
In addition, you'd want to check that interior rings do not intersect
the passed in geometry.
poly1.contains(poly2)
Interior rings in poly1 should not intersect poly2.
Tim
> Greetings,
> Bas
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
