[OpenLayers-Users] delete feature & vertexes
Eric Lemoine eric.c2c at gmail.com
Mon Aug 4 15:33:56 EDT 2008
If i read you correctly the select feature control and the modify
feature control are never activated at the same time. This should
limit conflicts, but it's not enough apparently.  When you select a
feature for deletion, are the feature's vertices rendered? If they are
it means the modify feature is somehow still activated. Instead of
deactivating the modify feature control when the select feature is
activated you could try removing it from the map and see if things go
better. Anyway that'd be great if you could provide a small test case
to help up reproduce the bug. Eric
2008/8/4, Adorian Ardelean <mynature at gmail.com>:
> Hi Eric,
> I have created a toolbox with buttons outside of OL. The tools have two
> states on and off (toggleControl).
> for(key in controls)
>     var control = controls[key];
>     if(element.value == key && element.checked)
>       control.activate();
>     else
>       control.deactivate();
> where element value is == name of a control as defined in code I indicated
> earlier.
> If delete button is selected a click on an entity removes it from layer; if
> edit button is selected then a click on an entity makes if enter modify
> mode. I think I need both of them, but if you have suggestions on how to
> combine delete and modify under the same modify control  please let me know
> (use of keys?).
> I think this issue is similar to this
> http://www.nabble.com/Delete-Feature-td16543538.html#a16543538 if I do not
> make a mistake in my interpretation.
> All the best,
> Adorian
> On Mon, Aug 4, 2008 at 6:27 PM, Eric Lemoine <eric.c2c at gmail.com> wrote:
>> Hi. Question: How do you distinguish that the user selects a feature
>> for deletion or modification? I'm trying to understand whether you
>> need two controls to achieve what you want - using a modify feature
>> control only might be sufficient and prevent potential problems
>> because of conflicts between the select feature and modify feature
>> controls. Cheers. Eric
>> > Hi,
>> > Thank you for your message. Yes it works, but...
>> > I have discovered that this problem is in relation with the modify
>> control I
>> > use within the same application. If I rem line for declaring modify
>> control
>> > the delete function behaves OK. If I include it, then after delete the
>> > vertexes remain. If more than one polygon on map then the vertexes
>> disappear
>> > from previous deleted polygon and appear where the last deleted polygon
>> > resided.... and so on. On some clicks succession a polygon may be
>> > redrawn
>> > (with lines and fill style), but no delete or drag or edit may be
>> performed.
>> >   var modifyOptions = {
>> >                 onModificationStart: function(feature) {
>> >                     OpenLayers.Console.log("start modifying", feature.id
>> >                 onModification: function(feature) {
>> >                     OpenLayers.Console.log("modified", feature.id);
>> >                 onModificationEnd: function(feature) {
>> >                     OpenLayers.Console.log("end modifying", feature.id);
>> >                 onDelete: function(feature) {
>> >                    OpenLayers.Console.log("delete", feature.id);
>> >  controls = {
>> >                 modify: new OpenLayers.Control.ModifyFeature(vectors,
>> > modifyOptions),
>> >                 deletefeature: new
>> OpenLayers.Control.SelectFeature(vectors,
>> > {onSelect:deleteFeature}),
>> > function deleteFeature(feature)
>> >   this.layer.destroyFeatures([feature]);
>> >   //this.layer.removeFeatures(feature);
>> > Any hints how to make delete and modify "cooperate"?
>> > All the best,
>> > Adorian
>> > On Mon, Aug 4, 2008 at 2:13 PM, Tim Schaub <tschaub at opengeo.org> wrote:
>> >> Hey-
>> >> Adorian Ardelean wrote:
>> >> > Hi,
>> >> > After upgrading to OL 2.6, delete feature function does not work
>> >> correctly:
>> >> > when a polygon or polyline is removed, the lines that define the
>> >> > disappear, but the vertexes not (the vertexes appear as the entity is
>> >> > selected). The code worked flawlessly in previous version. Is
>> something
>> >> > that I have to be aware and/or modify?
>> >> > declaration of control
>> >> > deletefeature: new
>> >> > OpenLayers.Control.SelectFeature(vectors,{onSelect:deleteFeature})
>> >> > delete function
>> >> > function deleteFeature(geometry)
>> >> >   this.layer.removeFeatures(geometry);
>> >> > Any hint that may solve this issue is appreciated,
>> >> I just tried the following and confirmed that the above works.
>> >> 1) open http://openlayers.org/dev/examples/draw-feature.html
>> >> 2) draw a polygon (note freehand is true here)
>> >> 3) in the firebug console, run this code:
>> >> var del = new OpenLayers.Control.SelectFeature(
>> >>     map.layers[3], {
>> >>         onSelect: function(feature) {
>> >>             map.layers[3].removeFeatures([feature]);
>> >> map.addControl(del);
>> >> del.activate();
>> >> 4) click on your polygon to see it removed
>> >> I suspect you really want to be calling destroyFeatures instead of
>> >> removeFeatures - unless you call feature.destroy elsewhere.
>> >> Tim
>> >> > Adorian
>> >> > Dr. Adorian Ardelean
>> >> > coordinator of myNature Project
>> >> > proiectul myNature
>> >> > str. Rascoala din 1907 nr 12
>> >> > Timisoara 300523
>> >> > Romania
>> >> > http://mybiosis.info/nature/portal.php?pagename=firstpage [a Romanian
>> >> > biodiversity-database]
>> >> > http://mybiosis.info/nature/portal.php?pagename=adorian [CV]
>> >> > _______________________________________________
>> >> > Users mailing list
>> >> > Users at openlayers.org
>> >> > http://openlayers.org/mailman/listinfo/users
>> >> Users mailing list
>> > proiectul myNature
>> > Timisoara 300523
>> > Romania
> proiectul myNature
> Timisoara 300523
> Romania
