[OpenLayers-Users] StyleMap and ModifyFeatures aren't
	compatible ?
    Arnd Wippermann
    arnd.wippermann at web.de
    Tue Aug  5 13:09:23 EDT 2008
Perhaps the way you declare your styles. Try to add PointRadius:5 etc. to
your lookup array, whether it changes something.
Arnd Wippermann
-----Ursprüngliche Nachricht-----
Von: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org] Im
Auftrag von George.Muammar
Gesendet: Dienstag, 5. August 2008 11:50
An: users at openlayers.org
Betreff: [OpenLayers-Users] StyleMap and ModifyFeatures aren't compatible ?
Hi List,
I have a functional ModifyFeatures control working on a Vector layer.
When I added a StyleMap to the vector layer (so I my features are coloured
differently based on an attribute), the ModifyFeatures control does not work
any more!
The behaviour is this:
polygons: when I click on the feature it get's selected (and it becomes 100%
opaque) but no handles appear and there is no handle functionalities any
more.
paths: can't even select it
points: everything ok (select and drag works).
Did this happen to anyone ?
Thanks
Some code:
here's how I define the style:
            var styleMap = new OpenLayers.StyleMap();
            var lookup = {
                1: {fillColor: "green", fillOpacity: 0.3, strokeColor:
"green",strokeWidth: 2},
                2: {fillColor: "blue", fillOpacity: 0.3, strokeColor:
"blue", strokeWidth: 2},
                3: {fillColor: "red", fillOpacity: 0.3, strokeColor: "red",
strokeWidth: 2}
            styleMap.addUniqueValueRules("default", "attribute", lookup);
            vLayer = new OpenLayers.Layer.Vector("Vettori", {
                styleMap: styleMap
here's how I create my controls:
function addControls()
		vLayer.display(true);
            panel = new OpenLayers.Control.Panel({'displayClass':
'olControlEditingToolbar'});
            conts = {
		    zoombox: new OpenLayers.Control.ZoomBox(),
                nav: new OpenLayers.Control.Navigation(),
		    point: new OpenLayers.Control.DrawFeature(vLayer,
                            OpenLayers.Handler.Point,
                            {'displayClass': 'olControlDrawFeaturePoint',
                             featureAdded:feature_added}),
                line: new OpenLayers.Control.DrawFeature(vLayer,
                            OpenLayers.Handler.Path,
                            {'displayClass': 'olControlDrawFeaturePath',
                polygon: new OpenLayers.Control.DrawFeature(vLayer,
                            OpenLayers.Handler.Polygon,
                            {'displayClass': 'olControlDrawFeaturePolygon',
               rectangle: new OpenLayers.Control.DrawFeature(vLayer,
                            OpenLayers.Handler.RegularPolygon,
                            {handlerOptions: {sides: 4, irregular: true},
                            'displayClass': 'olControlDrawFeatureRectangle',
                modify: new OpenLayers.Control.ModifyFeature(vLayer,
                           {'displayClass': 'olControlModifyFeature',
                            onModification: on_modification,
					mode:
OpenLayers.Control.ModifyFeature.RESHAPE |
OpenLayers.Control.ModifyFeature.DRAG |
OpenLayers.Control.ModifyFeature.RESIZE |
OpenLayers.Control.ModifyFeature.ROTATE})
	    for(var key in conts) {
                panel.addControls([conts[key]]);
            panel.activateControl(conts.nav);
		layerSwitcher = new
OpenLayers.Control.LayerSwitcher({'ascending':false});
		panZoomBar = new OpenLayers.Control.PanZoomBar()
		permalink = new OpenLayers.Control.Permalink('permalink');
            map.addControl( layerSwitcher );
            map.addControl( panZoomBar);
		map.addControl(permalink);
            map.addControl(panel);
View this message in context:
http://www.nabble.com/StyleMap-and-ModifyFeatures-aren%27t-compatible---tp18
827878p18827878.html
Users mailing list
Users at openlayers.org
http://openlayers.org/mailman/listinfo/users
