[OpenLayers-Users] SUM: OpenLayers, MapServer Map files and AGG
Bill Thoen bthoen at gisnet.com
Tue Aug 5 14:28:34 EDT 2008
Thanks to Arnd Wippermann who pointed out this snippet from the source
code in Layer.js; this was the clue I needed!
> perhaps it's the default map_imagetype in OL for the MapServer request.
>     DEFAULT_PARAMS: {
>         mode: "map",
>         map_imagetype: "png"
If you're use MapServer configured for AGG and you want to get those
nice anti-aliased lines from OpenLayers too, you've first got to define
an OUTPUTFORMAT section in your map file something like this:
  OUTPUTFORMAT
    NAME  'AGG'
    DRIVER  "AGG/PNG"
    MIMETYPE  "image/png"
    IMAGEMODE  RGB
    EXTENSION  "png"
  END
Then when you call OpenLayers.Layer.MapServer(), you have to override
the default parameter map_imagetype and set it to whatever you set as
'NAME' in your OUTPUTFORMAT section, as in the following example:
  var layer = new OpenLayers.Layer.MapServer( "World",
"http://my_domain.com/cgi-bin/mapserv",
       map_imagetype: 'AGG',
       layers: 'my_layer',
       map: '/var/www/html/my_mapfile.map',
    }, { singleTile: true, });
...and then you get a pretty map!
- Bill Thoen
