[OpenLayers-Users] StyleMap and ModifyFeatures aren't compatible ?
Alexandre Dube adube at mapgears.com
Thu Aug 7 07:55:08 EDT 2008
Sure I'll try, but anybody correct me if I am wrong with the explanation
please.
The vertices are vector features too that try to be drawn on the same
layer.  If a uniqueValueRules is set, then the a drawn feature must
respect it.  Since the vertices don't ( they don't have the related
attribute value, therefore don't respect the rule ) they are now drawn.
Well, in fact they are created, but not shown.  The elseFilter:true
means : if the feature doesn't respect the uniqueValueRules, use "this"
following rule instead.
Am I right ?
Alexandre
George.Muammar wrote:
> ALEX THAT WORKED JUST FINE!!!!!!! Great Stuff!
> Would you care to explain what the problem was ? For the record.
> Thanks to you and everyone else for the help.
> Alexandre Dube wrote:
>> Hi George,
>> Try to add the following lines :
>> var rules = [new OpenLayers.Rule({
>> symbolizer: {strokeColor:"#FF0000",strokeWidth: 2},
>> // symbolizer: {}, // instead if you want to keep default colors
>> elseFilter: true
>> styleMap.styles["default"].addRules(rules);
>> Hope this can help you,
>> Cheers,
>> Alexandre
>>> Hi List,
>>> I have a functional ModifyFeatures control working on a Vector layer.
>>> When I added a StyleMap to the vector layer (so I my features are
>>> coloured
>>> differently based on an attribute), the ModifyFeatures control does not
>>> work
>>> any more!
>>> The behaviour is this:
>>> polygons: when I click on the feature it get's selected (and it becomes
>>> 100%
>>> opaque) but no handles appear and there is no handle functionalities any
>>> more.
>>> paths: can't even select it
>>> points: everything ok (select and drag works).
>>> Did this happen to anyone ?
>>> Thanks
>>> Some code:
>>> here's how I define the style:
>>>             var styleMap = new OpenLayers.StyleMap();
>>>             var lookup = {
>>>                 1: {fillColor: "green", fillOpacity: 0.3, strokeColor:
>>> "green",strokeWidth: 2},
>>>                 2: {fillColor: "blue", fillOpacity: 0.3, strokeColor:
>>> "blue", strokeWidth: 2},
>>>                 3: {fillColor: "red", fillOpacity: 0.3, strokeColor:
>>> "red",
>>> strokeWidth: 2}
>>>             styleMap.addUniqueValueRules("default", "attribute", lookup);
>>>             vLayer = new OpenLayers.Layer.Vector("Vettori", {
>>>                 styleMap: styleMap
>>> here's how I create my controls:
>>> function addControls()
>>> 		vLayer.display(true);
>>>             panel = new OpenLayers.Control.Panel({'displayClass':
>>> 'olControlEditingToolbar'});
>>>             conts = {
>>> 		    zoombox: new OpenLayers.Control.ZoomBox(),
>>>                 nav: new OpenLayers.Control.Navigation(),
>>> 		    point: new OpenLayers.Control.DrawFeature(vLayer,
>>>                             OpenLayers.Handler.Point,
>>>                             {'displayClass': 'olControlDrawFeaturePoint',
>>>                              featureAdded:feature_added}),
>>>                 line: new OpenLayers.Control.DrawFeature(vLayer,
>>>                             OpenLayers.Handler.Path,
>>>                             {'displayClass': 'olControlDrawFeaturePath',
>>>                 polygon: new OpenLayers.Control.DrawFeature(vLayer,
>>>                             OpenLayers.Handler.Polygon,
>>>                             {'displayClass':
>>> 'olControlDrawFeaturePolygon',
>>>                rectangle: new OpenLayers.Control.DrawFeature(vLayer,
>>>                             OpenLayers.Handler.RegularPolygon,
>>>                             {handlerOptions: {sides: 4, irregular: true},
>>>                             'displayClass':
>>> 'olControlDrawFeatureRectangle',
>>>                 modify: new OpenLayers.Control.ModifyFeature(vLayer,
>>>                            {'displayClass': 'olControlModifyFeature',
>>>                             onModification: on_modification,
>>> 					mode: OpenLayers.Control.ModifyFeature.RESHAPE |
>>> OpenLayers.Control.ModifyFeature.DRAG |
>>> OpenLayers.Control.ModifyFeature.RESIZE |
>>> OpenLayers.Control.ModifyFeature.ROTATE})
>>> 	    for(var key in conts) {
>>>                 panel.addControls([conts[key]]);
>>>             panel.activateControl(conts.nav);
>>> 		layerSwitcher = new
>>> OpenLayers.Control.LayerSwitcher({'ascending':false});
>>> 		panZoomBar = new OpenLayers.Control.PanZoomBar()
>>> 		permalink = new OpenLayers.Control.Permalink('permalink');
>>>             map.addControl( layerSwitcher );
>>>             map.addControl( panZoomBar);
>>> 		map.addControl(permalink);
>>>             map.addControl(panel);
>> Alexandre Dubé
>> Mapgears
>> www.mapgears.com
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
Alexandre Dubé
Mapgears
www.mapgears.com
