[OpenLayers-Users] sld with wfs
Brenningmeyer, Todd tbrenningmeyer at maryville.edu
Sun Aug 10 09:50:20 EDT 2008
Hello,
I am trying to symbolize my data using an sld file with the tazmania-sld example as a template.  So far I haven't had too much success.  The sld document  loads and symbolizes the way I want when I open it in udig to validate it but when I display it in openlayers the points display using the default orange.  This is still listed as the default when I check the code in firebug and my symbology is listed under rules.  I'm not quite sure what I'm missing but any suggestions are welcome.  I will paste the sld and openlayers page below (it's pretty basic and just a reduced version of the tazmanian sld example).
Thanks,
Todd
__________________________OpenLayers Page___________________________________________
<html xmlns="http://www.w3.org/1999/xhtml">
  <head>
    <link rel="stylesheet" href="../theme/default/style.css" type="text/css" />
    <style type="text/css">
        #map {
            width: 800px;
            height: 475px;
            border: 1px solid black;
            background: #ccddff;
    </style>
    <script src="OpenLayers-2.6/lib/OpenLayers.js"></script>
    <script type="text/javascript">
        var map, sld, wfsLayers;
        var lon = 544134;
        var lat = 4183845;
        var zoom = 18;
        var format = new OpenLayers.Format.SLD();
        function init() {
            map = new OpenLayers.Map( 'map', {
              maxResolution: 200,
              maxExtent: new OpenLayers.Bounds(426367,3991789,756976,4312918),
              units: 'm',
              projection: 'EPSG:32634'
            map.addControl(new OpenLayers.Control.LayerSwitcher());
            OpenLayers.loadURL("amap2.xml", null, null, complete);
            baseLayer = new OpenLayers.Layer.WMS( "Greece",
                    "http://localhost/cgi-bin/mapserv.exe", {
                     layers: "ocean,country,hillshade_mask,provinces_utm,roads_utm",
                     map: "../htdocs/amap/amap.map",
                     transparent: "false",
                     format: "image/png" },
                     {singleTile: false}
        function getDefaultStyle(sld, layerName) {
            var styles = sld.namedLayers[layerName].userStyles;
            var style;
            for(var i=0; i<styles.length; ++i) {
                style = styles[i];
                if(style.isDefault) {
                    break;
            return style;
        function complete(req) {
            sld = format.read(req.responseXML || req.responseText);
            /*var hoverStyle = sld.namedLayers["Villages"].userStyles[1];
            //alert(sld.namedLayers["Villages"].userStyles[1].name);
            hoverStyle.defaultStyle = OpenLayers.Util.extend(
                {}, OpenLayers.Feature.Vector.style["select"]
            wfsLayers = [
                // use the sld UserStyle named "Default Styler"
        new OpenLayers.Layer.WFS( "villages",
                {typename: "villages",
               map:"../htdocs/amap/sites_wfs.map"},
               {extractAttributes: true},
                {styleMap: new OpenLayers.StyleMap({
                  "default": getDefaultStyle(sld, "Villages")//,
                  //"select": hoverStyle
            map.addLayers(wfsLayers);
            map.addLayer(baseLayer);
            map.zoomToExtent(new OpenLayers.Bounds(426367,3991789,756976,4312918));
            //map.setCenter(new OpenLayers.LonLat(lon, lat), zoom);
           // var hover = new OpenLayers.Control.SelectFeature(
           //     wfsLayers[1], {hover: true}
            //map.addControl(hover);
            //hover.activate();
        // set a new style when the radio button changes
        function setStyle(index) {
            wfsLayers[0].styleMap.styles["default"] = sld.namedLayers["Villages"].userStyles[index];
            // change the style of the features of the WaterBodies layer
            wfsLayers[0].redraw();
    </script>
  </head>
  <body onload="init()">
    <div id="map"></div>
    <p>This example uses a <a target="_blank" href="tasmania/sld-tasmania.xml">SLD
    file</a> to style the vector features. To construct layers that use styles
    from SLD, create a StyleMap for the layer that uses one of the userStyles in the
    namedLayers object of the return from format.read().</p>
    <p>Select a new style for the WaterBodies layer below:</p>
    <form>
      <input type="radio" name="style" onclick="setStyle(this.value)" checked="checked" value="0">Default Styler (zoom in to see more features)</input><br/>
      <input type="radio" name="style" onclick="setStyle(this.value)" value="3">Styler Test PropertyIsEqualTo</input><br/>
      <input type="radio" name="style" onclick="setStyle(this.value)" value="4">Styler Test WATER_TYPE</input><br/>
      <input type="radio" name="style" onclick="setStyle(this.value)" value="5">Styler Test PropertyIsGreaterThanOrEqualTo</input><br/>
      <input type="radio" name="style" onclick="setStyle(this.value)" value="6">Styler Test PropertyIsLessThanOrEqualTo</input><br/>
      <input type="radio" name="style" onclick="setStyle(this.value)" value="7">Styler Test PropertyIsGreaterThan</input><br/>
      <input type="radio" name="style" onclick="setStyle(this.value)" value="8">Styler Test PropertyIsLessThan</input><br/>
      <input type="radio" name="style" onclick="setStyle(this.value)" value="9">Styler Test PropertyIsLike</input><br/>
      <input type="radio" name="style" onclick="setStyle(this.value)" value="10">Styler Test PropertyIsBetween</input><br/>
      <input type="radio" name="style" onclick="setStyle(this.value)" value="11">Styler Test FeatureId</input><br/>
    </form>
  </body>
</html>
___________________________________SLD FILE_________________________________________
<sld:StyledLayerDescriptor
xmlns:sld="http://www.opengis.net/sld"
xmlns:ogc="http://www.opengis.net/ogc"
xmlns:gml="http://www.opengis.net/gml" version="1.0.0">
    <sld:NamedLayer>
      <sld:Name>Villages</sld:Name>
        <sld:UserStyle>
            <sld:Name>Default Styler</sld:Name>
            <sld:Title>Default Styler</sld:Title>
            <sld:Abstract>sld for amap</sld:Abstract>
         <sld:IsDefault>1</sld:IsDefault>
            <sld:FeatureTypeStyle>
                <sld:Name>simple</sld:Name>
                <sld:Title>title</sld:Title>
                <sld:Abstract>abstract</sld:Abstract>
                <sld:FeatureTypeName>Feature</sld:FeatureTypeName>
                <sld:SemanticTypeIdentifier>generic:geometry</sld:SemanticTypeIdentifier>
                <sld:Rule>
                    <sld:Name>name</sld:Name>
                    <sld:Abstract>Abstract</sld:Abstract>
                    <sld:MaxScaleDenominator>3000000</sld:MaxScaleDenominator>
                    <sld:PointSymbolizer>
                        <sld:Graphic>
                            <sld:Mark>
                                <sld:WellKnownName>circle</sld:WellKnownName>
                                <sld:Fill>
                                    <sld:CssParameter name="fill">
                                        <ogc:Literal>#0000FF</ogc:Literal>
                                    </sld:CssParameter>
                                    <sld:CssParameter name="fill-opacity">
                                        <ogc:Literal>1.0</ogc:Literal>
                                    </sld:CssParameter>
                                </sld:Fill>
                            </sld:Mark>
                        </sld:Graphic>
                    </sld:PointSymbolizer>
                </sld:Rule>
            </sld:FeatureTypeStyle>
        </sld:UserStyle>
    </sld:NamedLayer>
</sld:StyledLayerDescriptor>
