[OpenLayers-Users] Not change the size o polygons with zoom change
Jose A. C. joscalv at gmail.com
Tue Aug 12 05:16:42 EDT 2008
Hi!
I'm trying to rotate the symbols around their own center but I can´t; they
rotate around another point, In my opinion, the only choice is extend
OpenLayers.Renderer.symbol  in OpenLayers.Renderer.Elements, to define a
element for each angle that I need, from 0 up to 360 degrees.
Another possibility is to create polygons but they change their size with
the changes of the zoom of the map and I don´t want this, I need that their
size constant.
Has someone any idea of how I can do this?
Thank you for your help!!
 Regards!!!
2008/8/4 Jose A. C. <joscalv at gmail.com>
> Hi!
> This solution is perfect, but I need to rotate the polygons around their
> own center, since the rotate function doesn´t change their inclination, it
> just change their position.
> The code is:
>             features[4].geometry.rotate(30,new
> OpenLayers.Geometry.Point(map.maxExtent.left + (4 * slot) + (slot / 2), 0));
>             features[4].layer.drawFeature(features[4]);
>             features[1].geometry.rotate(30,new
> OpenLayers.Geometry.Point(5,5));
>             features[1].layer.drawFeature(features[1]);
> where features array comes from the example
> http://openlayers.org/dev/examples/graphic-name.html.
> Thanks!!!
> 2008/8/1 Christopher Schmidt <crschmidt at metacarta.com>
> On Fri, Aug 01, 2008 at 08:39:54AM +0200, Jose A. C. wrote:
>> > I'm making a map, and I need to create polygons on it that don´t change
>> its
>> > size when the zoom of the map change. I don´t use a mark because I need
>> to
>> > rotate it.
>> Sounds like you want this:
>> There's a set of constants in OpenLayers.Renderer.symbol  in
>> OpenLayers.Renderer.Elements which you could extend.
>> > I have another problem:  I draw different layers with different units
>> and
>> > when it is draw the size of the figure is the same in spite of  having
>> > different measures unit (Km and inches). The code is:
>> The units of the layer have no control over anything. Your units you are
>> providing are *map* units -- and the *name* you give to those units is
>> irrelevant. What you want to do is change the size of the units. If you
>> want to create something that's a different size, you need to provide
>> the correct size in current map units. (Your map is probably in
>> degrees.)
>> Regards,
>> Christopher Schmidt
>> MetaCarta
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20080812/d1a96b27/attachment.html
