[OpenLayers-Users] mousedown on marker and editingtoolbar
Eric Lemoine eric.c2c at gmail.com
Tue Aug 12 12:28:24 EDT 2008
I cant check right now but i thought only the temporary layer's
z-index was changed. May be completely wrong here. Eric
2008/8/12, Christopher Schmidt <crschmidt at metacarta.com>:
> On Tue, Aug 12, 2008 at 05:55:41PM +0200, Eric Lemoine wrote:
>> Someone will correct me if i'm telling sh^W: if there's a vector layer
>> above the markers layer browser events on the latter won't work. This
>> is the same problem that makes feature selection not work when
>> features are in multiple vector layers. How's the editing toolbar
>> behave if you make sure the markers layer is added to the map after
>> the vector layer? Eric
> It won't help behavior much if you have an editing tool active, since
> that sets the z-Index higher than the markers layer on activate.
> Regards,
> Christopher Schmidt
> MetaCarta
