[OpenLayers-Users] Tilecache Overlay Not Displaying Properly
Blake Crosby me at blakecrosby.com
Tue Aug 12 16:22:34 EDT 2008
What I ended up doing was using the transform() function to convert my
data in the database from ESPG:4329 to EPSG:900913.
Blake
Blake Crosby wrote:
> Hello,
> I've been pulling my hair trying to figure out how to get this working
> properly.
> Here is my current set up.
> Openlayers front end
> Tilecache to generate tiles
> Mapnik to generate maps
> Posgres to store data.
> I would like to overlay my data on top of a google map (Mercator).
> However my data is stored in lat/long WSG84 projection.
> I've tried every combination of configuration options. The closest I've
> gotten to is displaying my overlay at 0,0 on the map. The data is so
> small, that you would have to zoom in beyond level 15 to see it properly.
> It just appears as a little purple speck.
> You can see an example here:
> http://gateway.infiniteloop.ca/~bcrosby/tilecache/index3.html
> Here are various config options:
> Tilecache:
> [airways]
> type=Mapnik
> mapfile=/home/bcrosby/flightplan/airway_layer.xml
> metaTile=true
> spherical_mercator=true
> Mapnik:
> <Map srs="+proj=merc +a=6378137 +b=6378137 +lat_ts=0.0 +lon_0=0.0
> +x_0=0.0 +y_0=0 +k=1.0 +units=m +nadgrids=@null +no_defs">
> (let me know if you need more information in the mapnik config) The
> airways layer does not have an srs defined.
> The data should be appearing over Canada, at a proper zoom level. I
> suspect that there is a re-projection problem somewhere. Specifically,
> the data in the database is stored in lat/long units, however the map
> units are in meters. So tilecache/mapnik/openlayers is making requests
> for the data in the database based on meters, and not lat/long.
> Any suggestions?
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
