[OpenLayers-Users] free base maps
Nathan Gerber ngerber999 at gmail.com
Tue Aug 12 19:06:22 EDT 2008
True enough, I forgot all about that as I had actually made a local cache of
it for that exact reason.
Nathan Gerber
On Tue, Aug 12, 2008 at 5:20 PM, Anselm Hook <anselm at gmail.com> wrote:
> and onearth falls over pretty much all the time; it is remarkably unstable.
> - me
> On Tue, Aug 12, 2008 at 1:15 PM, Nathan Gerber <ngerber999 at gmail.com>wrote:
>> http://onearth.jpl.nasa.gov/ has global coverage (minus the poles) and is
>> decent for regional views but is limited to 15 meter per pixel as its best
>> resolution with 30m being the best in some regions. So if you need close up
>> views it won't fit your needs.
>> Sorry Gregor, I meant to do a reply-all on the original post.
>> Nathan Gerber
>> On Tue, Aug 12, 2008 at 3:45 PM, Bilge Tutak <bilge.tutak at gmail.com>wrote:
>>> Hi All,
>>> I am currently using Openlayers with the base map from Openlayers.
>>> I am curious if there are other free map services that can give base
>>> maps like the Openlayers maybe also with satellite imagery?
>>> I already know Google, Yahoo and MS ones. From these Google is the
>>> most useful for me in terms of maps, but
>>> I can not use it because my application is not running on single
>>> domain (actually does not run on an actual domain, except like
>>> localhost).
>>> Thanks,
>>> Bilge.
>>> Users mailing list
>>> Users at openlayers.org
>>> http://openlayers.org/mailman/listinfo/users
>> Users mailing list
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20080812/e2330c51/attachment.html
