[OpenLayers-Users] mousedown on marker and editingtoolbar
Walter Lorenzetti lorenzetti at gis3w.it
Wed Aug 13 03:14:52 EDT 2008
Eric Lemoine ha scritto:
> I cant check right now but i thought only the temporary layer's
> z-index was changed. May be completely wrong here. Eric
> 2008/8/12, Christopher Schmidt <crschmidt at metacarta.com>:
>> On Tue, Aug 12, 2008 at 05:55:41PM +0200, Eric Lemoine wrote:
>>> Someone will correct me if i'm telling sh^W: if there's a vector layer
>>> above the markers layer browser events on the latter won't work. This
>>> is the same problem that makes feature selection not work when
>>> features are in multiple vector layers. How's the editing toolbar
>>> behave if you make sure the markers layer is added to the map after
>>> the vector layer? Eric
>> It won't help behavior much if you have an editing tool active, since
>> that sets the z-Index higher than the markers layer on activate.
>> Regards,
>> Christopher Schmidt
>> MetaCarta
Thanks for reply!!
I'll find a new way...
Walter
