[OpenLayers-Users] Map Layer Requirements
Eric Lemoine eric.c2c at gmail.com
Thu Aug 14 00:06:25 EDT 2008
Obviously :-)
2008/8/14, Bill Thoen <bthoen at gisnet.com>:
> Thanks. I had to change the false to true, and then it worked.
> Eric Lemoine wrote:
>> Hi Bill. You need your vector layer be a base layer. By default vector
>> layers aren't base layers so you need an explicit option for this at
>> creation time: new OpenLayers.Layer.Vector("vector", {isBaseLayer:
>> false}). Hope i am correct and this is helping :-) Eric
>> 2008/8/13, Bill Thoen <bthoen at gisnet.com>:
>>> I'm trying to set up some little experimental maps in OpenLayers using
>>> just a vector layer -- no base map. It's not working and I wondered is a
>>> base map layer required, or can you supply all the necessary options
>>> when you create the map object?
>>> Users mailing list
>>> Users at openlayers.org
>>> http://openlayers.org/mailman/listinfo/users
> Users mailing list
