[OpenLayers-Users] CQL queries with WFS
Brenningmeyer, Todd tbrenningmeyer at maryville.edu
Thu Aug 14 10:02:49 EDT 2008
Bart,
I tried escaping the quotes around the value of the nomos but unfortunately it didn't change the returned results.  I used backslashes in front of the single quotes around Eleia.  Is this what you had in mind?  It may be that I'm not escaping the right part of the filter.
Thanks,
Todd
           wfsLayer = new OpenLayers.Layer.WFS( "villages",
                http://localhost/cgi-bin/mapserv.exe?map=../htdocs/amap/sites_wfs.map&CQL_FILTER=nomos=\'Eleia\'&typename=villages&request=getfeature&version=1.0.0&service=wfs,{
                styleMap: oStyleMap
From: bartvde at osgis.nl [mailto:bartvde at osgis.nl]
Sent: Thu 8/14/2008 8:52 AM
To: Brenningmeyer, Todd
Cc: Andreas Hocevar; Eric Lemoine; Openlayers Users List
Subject: Re: [OpenLayers-Users] CQL queries with WFS
Have you tried escaping the value of your parameter CQL_FILTER?
Best regards,
Bart
> Thanks Andreas and Eric.  I've tried a few different options with the
> filter but without success.  I'm using the following filter and have tried
> this with the map location moved into the params section and a few other
> times with everything in a single URL request but still no luck.  The
> request returns all of the villages with none of these filtered out.  If
> you have any ideas that might help please let me know.  Thanks again for
> your help.
> Todd
>                 "http://localhost/cgi-bin/mapserv.exe?map=../htdocs/amap/sites_wfs.map&CQL_FILTER=nomos='Eleia'
> <http://localhost/cgi-bin/mapserv.exe?map=../htdocs/amap/sites_wfs.map&CQL_FILTER=nomos='Eleia',{// <http://localhost/cgi-bin/mapserv.exe?map=../htdocs/amap/sites_wfs.map&CQL_FILTER=nomos='Eleia',{//<Filter> ><PropertyIsEqualTo><PropertyName>nom_nr</PropertyName><Literal>39</Literal></PropertyIsEqualTo></Filter>
>                service: "WFS",
>                typename: "villages",
>                request: "getfeature",
>                version: "1.0.0"
>                 extractAttributes: true
> Attempt with the params moved into the URL:
>                 "http://localhost/cgi-bin/mapserv.exe?map=../htdocs/amap/sites_wfs.map&CQL_FILTER=nomos='Eleia'&typename=villages&request=getfeature&version=1.0.0&service=wfs",{
>                 styleMap: oStyleMap
> From: Andreas Hocevar [mailto:andreas.hocevar at gmail.com]
> Sent: Wed 8/13/2008 7:11 AM
> To: Eric Lemoine
> Cc: Brenningmeyer, Todd; Openlayers Users List
> Hi,
> On Wed, Aug 13, 2008 at 2:08 PM, Eric Lemoine <eric.c2c at gmail.com> wrote:
>> On Wed, Aug 13, 2008 at 11:49 AM, Andreas Hocevar
>> <andreas.hocevar at gmail.com> wrote:
>>> Hi,
>>> Since CQL_FILTER is not part to the WMS spec, the best way is to add
>>> the filter to the WMS url, e.g.
>>> var layer=new OpenLayers.Layer.WMS("cql",
>>> "http://your-server/wms?CQL_FILTER=foo<3", params, options);
>> Todd's question related to WFS, but I guess the response is similar,
>> isn't it?
> Should be, yes. Just s/WMS/WFS/gi.
> Regards,
> Andreas.
> No virus found in this incoming message.
> Checked by AVG - http://www.avg.com <http://www.avg.com/>  <http://www.avg.com/>
> Version: 8.0.138 / Virus Database: 270.6.2/1609 - Release Date: 8/13/2008
> 6:43 AM
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
