[OpenLayers-Users] GetFeature VS MapScript generated csv file
Alexandre Dube adube at mapgears.com
Fri Aug 15 16:02:31 EDT 2008
Hi all,
    In my application, I dynamically build a <select> element with
cities as options using a GetFeature request and reading from GML format
to generate it.
    It works perfectly but is kinda slow because of the size of the GML
format.  A dev and friend of mine suggested that I should generate my
own text file using phpMapScript.  It was quite easy to do and works
perfectly.  It generates a file which uses the same format as the
OpenLayers.Format.Text ( tab separated values, coordinates and title as
city name ).
    Now I want to replace the GML format by Text format but don't really
understand how this must be done.
    I tried this :
        OpenLayers.loadURL("/bdga/csvCityBuilder.php", '', this, setCities);
    and the file is created...  but my php file is not a standard
request.  It doesn't return anything, it only creates a file.
    I could load the generated file with standard javascript function,
but I was wondering if there is already something in OpenLayers I could
use, like the following ( which obviously isn't working ).  Maybe I'm
missing something.
        oText = new OpenLayers.Format.Text();
        oFeatures = oText.read(response.responseText);
    Bellow is the GML version of it which works fine.  Any help would be
appreciated.
// a GetFeature on layer BDGA_HABIT_P_POINT to get all cities and their
// coordinates.  See setCites function for more info.
sUrl = sMSURL;
sUrl += "?map=";
sUrl += sBDGAMapPath;
sUrl += "&service=WFS&version=1.0.0&request=GetFeature";
sUrl += "&TYPENAME=BDGA_HABIT_P_POINT";
OpenLayers.loadURL(sUrl, '', this, setCities);
// add one option per city to a select html element with value equal to
// the city coordinates ( longitude, latitude )
function setCities(response) {
    oGML =  new OpenLayers.Format.GML();
    oFeatures = oGML.read(response.responseText);
    var aCities = new Array();
    // put the results in an array first to be able to sort it
    for (var key in oFeatures){
        var szValue = "";
        szValue += oFeatures[key].geometry.x;
        szValue += ",";
        szValue += oFeatures[key].geometry.y
        aCities[key] = {
          cityName: oFeatures[key].attributes['HAP_NM_TOP'],
          lonlat: szValue
    // sort the array by city name
    aCities.sort(sortByCityName);
    // create on option per city and add it to the select element
    var oSelect=document.getElementById("zoomToCity");
    for (i=0; i<aCities.length; i++){
        var oOption = document.createElement('option');
        oOption.text=aCities[i]['cityName'];
        oOption.value=aCities[i]['lonlat'];
        try
            oSelect.add(oOption,null); // standards compliant
        catch(ex)
            oSelect.add(oOption); // IE only
    // The list has finished to be created, so enable it and remove the
first
    // option that contained the "please wait" msg
    oSelect.disabled = "";
    oSelect.remove(0);
// returns the aCities array sorted by cityName
function sortByCityName(a, b) {
    var x = a.cityName.toLowerCase();
    var y = b.cityName.toLowerCase();
    return ((x < y) ? -1 : ((x > y) ? 1 : 0));
Alexandre Dubé
Mapgears
www.mapgears.com
