[OpenLayers-Users] Toggle visibility controls
Eric Lemoine eric.c2c at gmail.com
Tue Aug 19 11:31:58 EDT 2008
But just removing the controls from the map as mentioned by George is
much better. Where was my mind :) Eric
2008/8/19, Eric Lemoine <eric.c2c at gmail.com>:
> You can probably loop over your controls and for each set its div's
> style.display property to "none". Eric
> 2008/8/19, Bas Couwenberg <bascouwenberg at gmail.com>:
>> Hello,
>> I am using OpenLayers in a Swing browser in our Java application. I have a
>> method that captures the maps on screen in OL and saves them to the disk.
>> Now I would like to have all the panning/zooming/layer controls to be
>> invisible when I capture the screen so I only have the map saved. Is it
>> possible to toggle the visibility of these controls?
>> Best regards,
>> Bas Couwenberg
