[OpenLayers-Users] GetFeatureInfo on Single Click, Zoom In on Double Click
jvanulde jvanulde at NRCAN.GC.CA
Wed Aug 20 10:47:21 EDT 2008
Hi Eric,
I am following the demo so I am using the following:
map.events.register('click', map, function (e) { ... }
Is there an example of using the OpenLayers.Handler.Click that does more or
less the same thing that I can look at?
Thank you for your help.
Joost
Eric Lemoine-3 wrote:
> On Wed, Aug 20, 2008 at 4:45 AM, jvanulde <jvanulde at nrcan.gc.ca> wrote:
>> Hi all,
>> Currently I have a singleclick handler that does a getFeatureInfo request
>> on
>> an active layer (as per the demo).  Of course everytime I double click to
>> zoom and recenter the map a getFeatureInfo request is made.  Is there an
>> elegant way to deal with this?  Ideally, I don't want a getFeatureInfo
>> request to be made everytime a user double clicks the map to zoom in and
>> recenter.  Any suggestions would be helpful.
> Hi
> Do you use OpenLayers.Handler.Click for registering the getFeatureInfo
> handler? If you use that I guess double-clicking for zooming shouldn't
> trigger getFeatureInfo. Unless I'm missing something; in that case,
> some code would help me.
> Regards,
> Eric
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
View this message in context: http://www.nabble.com/GetFeatureInfo-on-Single-Click%2C-Zoom-In-on-Double-Click-tp19062128p19069989.html
