[OpenLayers-Users]  using a proxy
    LaurentPierre
    mail at lespierre.org
    Thu Aug 21 04:30:44 EDT 2008
I'm trying to use a proxy with openlayers in order to request ws on
different ports than the site (on the same machine in facts).  In order to
do that I set the proxy in the code but not all the calls are made through
it  :
var url =  map.layers[0].getFullRequestString(.....  generates a call
through the proxy
while this one
new OpenLayers.Layer.WMS("edfgeo:departement - Tiled",
"http://localhost:8080/geoserver/wms", ....
no.
Here's the 2 firebug traces :
http://localhost/cgi-bin/proxy.py?url=http%3A%2F%2Flocalhost%3A8080%2Fgeoserver%2Fwms%3FSTYLES%3D%26LAYERS%3Dedfgeo%253Apactedep%26WIDTH%3D800%26HEIGHT%3D560%26SRS%3DEPSG%253A2154%26FORMAT%3Dimage%252Fpng%26SERVICE%3DWMS%26VERSION%3D1.1.1%26REQUEST%3DGetFeatureInfo%26EXCEPTIONS%3Dapplication%252Fvnd.ogc.se_xml%26BBOX%3D753290.28095%252C6200497.152087%252C899406.792137%252C6302778.709918%26X%3D55%26Y%3D119%26INFO_FORMAT%3Dtext%252Fhtml%26QUERY_LAYERS%3Dedfgeo%253Adepartement%26FEATURE_COUNT%3D50
http://localhost:8080/geoserver/wms?STYLES=&LAYERS=edfgeo%3Apactedep&WIDTH=1200&HEIGHT=840&SRS=EPSG%3A2154&FORMAT=image%2Fpng&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&BBOX=825492.3851108723,6251038.624999397,827204.6879763438,6252237.237005227
and a code fragment :
	function showName(e){
                        REQUEST: "GetFeatureInfo",
                        EXCEPTIONS: "application/vnd.ogc.se_xml",
                        BBOX: map.getExtent().toBBOX(),
                        X: e.xy.x,
                        Y: e.xy.y,
                        INFO_FORMAT: 'text/html',
                        QUERY_LAYERS: map.layers[2].params.LAYERS,
                        FEATURE_COUNT: 50,
                        WIDTH: map.size.w,
                        HEIGHT: map.size.h
        function init(){
	    OpenLayers.ProxyHost="/cgi-bin/proxy.py?url=";
	    toolTip = document.getElementById("toolTip");
            var bounds = new OpenLayers.Bounds(
                -82496.16303893644, 5966463.161241372,
                1413736.911514963, 7198720.496439878
            var options = {
                controls: [],
                maxExtent: bounds,
                maxResolution: 5844.66044747617,
                projection: "EPSG:2154",
                units: 'm'
            map = new OpenLayers.Map('map', options);
            // setup tiled layer
            tiled = new OpenLayers.Layer.WMS(
                    styles: '',
                    layers: 'edfgeo:departement',
                    width: '800',
                    height: '618',
                    srs: 'EPSG:2154',
                    format: 'image/png',
                    tiled: 'true',
                    tilesOrigin : "-82496.16303893644,5966463.161241372"
                {buffer: 0}
Is it a known problem or did I make a mistake ?
Thanks
Laurent Pierre
View this message in context: http://www.nabble.com/using-a-proxy-tp19084627p19084627.html
