[OpenLayers-Users] Custom markers
Indika Tantrigoda indika85 at gmail.com
Fri Aug 22 12:56:11 EDT 2008
Thanks Eric, after I removed featureClass, got what I was looking for
Regards,
Indika
2008/8/22 Eric Lemoine <eric.c2c at gmail.com>
> Hi. If you use externalGraphics do not pass any featureClass to the
> WFS constructor. Also check the name of the external graphics prop i
> can't remember if there's a trailing s or not. Eric
> 2008/8/22, Indika Tantrigoda <indika85 at gmail.com>:
> > Hi all,
> > I seem to have some trouble with the following
> >      var symbolizer = OpenLayers.Util.applyDefaults(
> >         {externalGraphic: "./marker-blue.png", pointRadius: 20},
> >         OpenLayers.Feature.Vector.style["default"]);
> >         wfs_test = new OpenLayers.Layer.WFS( "WFS Test",
> >                         "http://localhost:8080/geoserver/wfs",
> >                         {typename: "topp:cities",
> >                          maxfeatures: 10
> >                         {featureClass: OpenLayers.Feature.WFS,
> >                          styleMap: new OpenLayers.StyleMap({
> >                                   "default": symbolizer
> > However I still get the same red marker.
> > Thanks in advance.
> > Regards,
> > Indika
> > 2008/8/21 Eric Lemoine <eric.c2c at gmail.com>
> >> Hi. maxfeatures tells the WFS how many features you want to receive at
> >> most. Eric
> >> 2008/8/20, Indika Tantrigoda <indika85 at gmail.com>:
> >> > Hi all,
> >> > I have managed to display some point data as a WFS layer using
> >> >                  maxfeatures: 10
> >> >                 { featureClass: OpenLayers.Feature.WFS}
> >> > The points are displayed as markers similar to the examples.
> >> > Would there be any way to have a custom marker instead of the
> >> > traditional
> >> > one ? I plan to have multiple
> >> > point layers (as WFS layers) with different markers for each layer.
> >> > Also what exactly does the maxfeatures: 10 do ?
> >> > Thanks in advance.
> >> > Regards,
> >> > Indika
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20080822/6100789f/attachment.html
