[OpenLayers-Users] using openlayers.rule with existing style
Eric Lemoine eric.c2c at gmail.com
Fri Aug 22 14:15:52 EDT 2008
Maybe the OpenLayers version you're using does support the display
style property, that one was introduced after the others. I think 2.6
has it. Eric
2008/8/22, Brenningmeyer, Todd <tbrenningmeyer at maryville.edu>:
> Eric,
> Thanks.  That helped and I now see that I may be able to do this with the
> addUniqueValueRules?  At least it seems that this is the case.  I was unable
> to get the symbolizer with {display: "none"} to hide the selected features.
> When I change the fillcolor the color changes on redraw but when display:
> "none" is used nothing seems to change.  Is there another way to set this?
> Thanks again,
> Todd
> ________________________________
> From: Eric Lemoine [mailto:eric.c2c at gmail.com]
> Sent: Thu 8/21/2008 1:15 AM
> To: Brenningmeyer, Todd; users at openlayers.org
> Subject: Re: [OpenLayers-Users] using openlayers.rule with existing style
> Hi. A Rule object as opposed to a Filter object must be passed to
> addRules, the code snippet you first posted had this right. If your
> goal is to not display points matching some criteria, your rule's
> symbolizer will be {display: "none"}. Also, one thing to pay attention
> to: if the feature property is an integer your must have an integer as
> your filter's value (value: "1" looks suspicious to me, but i dont
> know what your data is). Hope this helps. Eric
> 2008/8/20, Brenningmeyer, Todd <tbrenningmeyer at maryville.edu>:
>> I was able to get the function to run without crashing but the rules I
>> apply
>> do not seem to change the characteristics of the features.  None of the
>> features are filtered when I apply the "filter.comparison.EQUAL_TO".  Am I
>> applying this correctly or does it not work the way I thought?  Any help
>> is
>> appreciated.
>> Todd
>>         function setStyle(index) {
>>          if(index == 'all'){
>>             gmlLayer.styleMap.styles["default"] =
>> sld.namedLayers["Inked"].userStyles[0];
>>             gmlLayer.redraw();
>>             } else {
>>             var rule = new OpenLayers.Filter.Comparison({
>>            type: OpenLayers.Filter.Comparison.EQUAL_TO,
>>            property: "plan_inkd",
>>            value: "0",
>>            symbolizer: {fillColor:"FFFF00"}
>>           sld.namedLayers["NotInked"].userStyles[0].addRules([rule]);
>> sld.namedLayers["NotInked"].userStyles[0];
>>             gmlLayer.redraw();
>> From: Brenningmeyer, Todd
>> Sent: Wed 8/20/2008 10:50 AM
>> To: users at openlayers.org
>> Subject: using openlayers.rule with existing style
>> Hello,
>> I have a series of points that are symbolized with an sld.  Each point
>> represents a site of a particular period (classical, byzantine, etc.).
>> What
>> I want to do is allow the user to turn points on and off by clicking a
>> checkbox on the side (all points are in a "sites" table in postgresql).
>> I'm
>> currently using a filter in the sld to symbolize sites of each period
>> differently.  Can I apply a new filter using openlayers.rule with a new
>> openlayers.filter to turn layers on and off?  The function below is called
>> when someone clicks on the checkbox.  The code below comes up with an
>> "OpenLayers.rule is not a constructor" error when it is executed.  I
>> suppose
>> my question is whether or not the features can be filtered to display or
>> not
>> display using this method and if so how would I do this?  If it's not a
>> reasonable approach does anyone have ideas about how something like this
>> could be done?  I would rather not separate all of the features into
>> different files and an sld with individual styles for each possible
>> combination of clicks could get very long.
>> Thanks,
>> Todd
>>           var rule = new OpenLayers.rule({
>>           filter: new OpenLayers.Filter.Comparison({
>>            value: "1"
>>           symbolizer: {
>>            Point: { fillColor:"FFFF00", strokeColor: "blue"}
>> sld.namedLayers["Villages"].userStyles[0].addRule(rule);
>>             gmlLayer.redraw();
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
