[OpenLayers-Users] SLD file and labels
Eric Lemoine eric.c2c at gmail.com
Fri Aug 22 16:15:02 EDT 2008
Not that i'm aware of, but i'd be quite to hear otherwise :) Eric
2008/8/22, Zer <hcan at hotmail.com>:
> Hello all,
> Does anyone know if there has been any progress in this case? Would be a
> nice feature!
> Thanks,
> -Z
> Tim Schaub-3 wrote:
>> Hey-
>> hcan-hcan wrote:
>>> Hi!
>>> I'm using the label examples from camptocamp's sandbox
>>> (vectors-with-text).
>>> Works just fine! Now I have started to  create some themes using and  SLD
>>> xml file, the same way as in the Styled Layer Descriptor (SLD) Example.
>>> Is
>>> there a way to get the labels working using an SLD file? What I had in
>>> mind
>>> was something like this:
>>> <sld:CssParameter name="label">
>>> 	<ogc:Literal>name: ${name}</ogc:Literal>
>>> </sld:CssParameter>
>>> <sld:CssParameter name="fontColor">
>>> 	<ogc:Literal>red</ogc:Literal>
>>> </sld:CssParameter>
>>> <sld:CssParameter name="fontWeight">
>>> 	<ogc:Literal>bold</ogc:Literal>
>>> </sld:CssParameter>
>> The SLD spec includes an sld:TextSymbolizer element.  This element has
>> optional children sld:Font, sld:Label, and sld:Fill - all of which are
>> supported (in the writers) as of
>> http://trac.openlayers.org/changeset/7333.
>> If the SLD parser is given a symbolizer keyed by 'Text', it will write
>> In OpenLayers a text symbolizer should have the following properties:
>> label, fontFamily, fontSize, fillColor, fillOpacity
>> (We can add in support for fontStyle and fontWeight.)
>> It would be great to get the vectors labeling stuff in the trunk - and
>> we should make sure we're following the same conventions for describing
>> a text symbolizer.
>> Tim
>>> However, I could not get it working. Does anyone know if this is
>>> possible?
>>> Or has another solution...
>>> Thanks,
>>> //H
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
> http://www.nabble.com/SLD-file-and-labels-tp18346791p19113813.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
