[OpenLayers-Users] Fixed Scales & minScale problem
Alexandre Dube adube at mapgears.com
Tue Aug 26 16:55:54 EDT 2008
Ok, I tried this and it worked :
        olWFSRoads = new OpenLayers.Layer.WFS(
            "Routes - WFS", sMSURL,
            { typename: "BDGA_ROUTE_L_ARC", map: sBDGAMapPath },
            { extractAttributes: true,
              numZoomLevels: 2, scales: [25000, 10000],      //
              //minScale: 25000,
              typename: "BDGA_ROUTE_L_ARC", styleMap: oStyleMap
Is this a good workaround ?
Alexandre Dube wrote:
> I saw this in Layer.js at line 690 ( OL 2.6 )
> // Do not use the scales/resolutions at the map level if
> // minScale/minResolution and maxScale/maxResolution are
> // specified at the layer level
> Ok ?  But I want to use both.  I don't understand why we can't set a
> minScale to a layer at the same time we specify our own scale ranges.  I
> mean, I work for some of my layers and other not...  I'm confused !
> Is there a way around ?
> Alexandre
>> Hi everybody,
>>   I've got a strange behavior in my OL application.  I've got some
>> layers with simple params like minScale/maxScale like the following :
>> // layer
>>             { extractAttributes: true, minScale: 25000,
>>   I use the following map options :
>> // old way
>>         var oMapOptions = {
>>             controls: [],
>>             units: 'm',
>>             maxResolution: 156543.0339,
>>             maxExtent: new OpenLayers.Bounds(
>>                 -1192709.604,
>>                 -204908.6926,
>>                 1172293.7082,
>>                 2338511.3665
>>             projection: new OpenLayers.Projection("EPSG:32198")
>>   I want to use more rounded scale numbers, like the following :
>> // new way
>>         var oMapOptions = {
>>             controls: [],
>>             units: 'm',
>>                 -1192709.604,
>>                 -204908.6926,
>>                 1172293.7082,
>>                 2338511.3665),
>>             projection: new OpenLayers.Projection("EPSG:32198"),
>>             numZoomLevels: 11,
>>             scales:  [13000000, 8000000, 4000000, 2000000,
>> 1000000,                   // <---------------
>>                       500000, 250000, 100000, 50000, 25000, 10000]
>> The problem is, some of my layer loses their minScale value ( like the
>> one above, olWFSRoads ).  It's changed to 13000000 as soon as it's added
>> to the map !  I have an other WMS layer that does the same thing, and
>> some others don't...  But they have the same params.
>> Is this a bug or I'm missing something new when I set scales : [...] as
>> a new map option ?
Alexandre Dubé
Mapgears
www.mapgears.com
