[OpenLayers-Users] Compressing 2.6 OpenLayers (OpenLayers.Control is null or not an object)
Eric Lemoine eric.c2c at gmail.com
Thu Aug 28 13:29:38 EDT 2008
Hi. This is really weird. Open OpenLayers.js in an editor and search
for "OpenLayers.Control = OpenLayers.Class", you should get one
occurence of this, otherwise your build isn't valid, for some reason.
Eric
2008/8/28, Linda Rawson <linda.rawson at gmail.com>:
> I have been on another project so I am just getting around to compressing my
> version of openlayers.  So I thought I would try the stable version first
> before adding my stuff into it.
> Here are my steps:
> 1.  Grabbed latest stable build.
> 2.  Switched to build directory.
> 3.  python ./build.py full.cfg
> 4.  Copied Openlayers.js (466 KB) to ..  (1 directory above lib, same level
> as build, img, theme, tools)
> 5.  Moved SpericalMercator.html example to this directory also.
> 6.  Changed to point to
> <script src="OpenLayers.js"></script>
> 7.  Run and get the following error:
> Microsoft JScript runtime error:  'OpenLayers.Control' is null or not an
> object.
> I also get this when I use what I used in 2.5 to compress and it does not
> work in 2.6.
> Does anybody have any idea what to do with this error?  I would really like
> to compress Openlayers.
> Thanks!
> Linda Rawson
