[OpenLayers-Users] Layer selection in LayerSwitcher
Erik Uzureau euzuro at gmail.com
Thu Aug 28 15:52:18 EDT 2008
Hello Semantica, can we see a version of this layer switcher live somewhere?
erik
On Thu, Aug 28, 2008 at 2:50 PM, Semantica <jvanulde at nrcan.gc.ca> wrote:
> Sorry, in my last post I forgot to indicate how to access the selected layer.
> As you will see I added a property on the layerSwitcher called activeLayer.
> This property stores the layer id (layer.params.LAYERS).
> To make a layer active, the user clicks on the layer title in the
> layerSwitcher.  The title bar is highlighed with a border and the
> activeLayer property is set the the layer id.  So to access the layer
> associated with that id (i.e. the active layer) you simply do this:
> var layerId = layerSwitcher.activeLayer;
> var activeLayer = map.getLayer(layerId);
> Then you can access the layer properties for example if you wan't the
> getFeatureInfo request string you would do the following:
> var url =   activeLayer.getFullRequestString({
>                                REQUEST: "GetFeatureInfo",
>                                EXCEPTIONS: "application/vnd.ogc.se_xml",
>                                BBOX: activeLayer.map.getExtent().toBBOX(),
>                                X: evt.xy.x,
>                                Y: evt.xy.y,
>                                INFO_FORMAT: 'text/html',
>                                QUERY_LAYERS: activeLayer.params.LAYERS,
>                                WIDTH: activeLayer.map.size.w,
>                                HEIGHT: activeLayer.map.size.h});
> Again, I hope this helps.
> Cheers and good luck!
> Bas Couwenberg wrote:
>> Hello,
>> is it possbile with the LayerSwitcher control to select a layer (I don't
>> mean turn invisible) which I then could use to change it opacity. The
>> opacity part works well from the examples but I want to do this per layer
>> I
>> select.
>> Best regards,
>> Bas Couwenberg
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
> View this message in context: http://n2.nabble.com/Layer-selection-in-LayerSwitcher-tp789021p790516.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
