[OpenLayers-Users] Compressing 2.6 OpenLayers (OpenLayers.Control is null or not an object)
Eric Lemoine eric.c2c at gmail.com
Thu Aug 28 16:06:19 EDT 2008
Do you have a FireBug <script> tag in your html file? Eric
2008/8/28, Linda Rawson <linda.rawson at gmail.com>:
> Something is wrong with the following lines:
> for(var i=0;i<scripts.length;++i){
> if(scripts[i].src.indexOf("firebug.js")!=-1){
> OpenLayers.Util.extend(OpenLayers.Console,console);
> break;
> If I remove them everything runs fine.
> Linda
> On Thu, Aug 28, 2008 at 11:29 AM, Eric Lemoine <eric.c2c at gmail.com> wrote:
>> Hi. This is really weird. Open OpenLayers.js in an editor and search
>> for "OpenLayers.Control = OpenLayers.Class", you should get one
>> occurence of this, otherwise your build isn't valid, for some reason.
>> Eric
>>  > I have been on another project so I am just getting around to
>> compressing my
>> > version of openlayers.  So I thought I would try the stable version
>> > first
>> > before adding my stuff into it.
>> > Here are my steps:
>> > 1.  Grabbed latest stable build.
>> > 2.  Switched to build directory.
>> > 3.  python ./build.py full.cfg
>> > 4.  Copied Openlayers.js (466 KB) to ..  (1 directory above lib, same
>> level
>> > as build, img, theme, tools)
>> > 5.  Moved SpericalMercator.html example to this directory also.
>> > 6.  Changed to point to
>> > <script src="OpenLayers.js"></script>
>> > 7.  Run and get the following error:
>> > Microsoft JScript runtime error:  'OpenLayers.Control' is null or not an
>> > object.
>> > I also get this when I use what I used in 2.5 to compress and it does
>> > not
>> > work in 2.6.
>> > Does anybody have any idea what to do with this error?  I would really
>> like
>> > to compress Openlayers.
>> > Thanks!
>> > Linda Rawson
> Linda Rawson
