[OpenLayers-Users] Compressing 2.6 OpenLayers (OpenLayers.Control is null or not an object)
Linda Rawson linda.rawson at gmail.com
Thu Aug 28 16:19:28 EDT 2008
I am using IE 1.7.
In firefox I get the following error:
OpenLayers.Class is not a function
file:///C:/temp/MyOpenLayers/mytestbuild/OpenLayers-2.6/OpenLayers-2.6/OpenLayers.js
Line 804
On Thu, Aug 28, 2008 at 2:17 PM, Linda Rawson <linda.rawson at gmail.com>wrote:
>  No.  It is just the standard spericalmercator.html file in the examples
> directory.
> I am using python 2.5.2.
> On Thu, Aug 28, 2008 at 2:06 PM, Eric Lemoine <eric.c2c at gmail.com> wrote:
>> Do you have a FireBug <script> tag in your html file? Eric
>> 2008/8/28, Linda Rawson <linda.rawson at gmail.com>:
>> > Something is wrong with the following lines:
>> > for(var i=0;i<scripts.length;++i){
>> > if(scripts[i].src.indexOf("firebug.js")!=-1){
>> > OpenLayers.Util.extend(OpenLayers.Console,console);
>> > break;
>> > If I remove them everything runs fine.
>> > Linda
>> > On Thu, Aug 28, 2008 at 11:29 AM, Eric Lemoine <eric.c2c at gmail.com>
>> wrote:
>> >> Hi. This is really weird. Open OpenLayers.js in an editor and search
>> >> for "OpenLayers.Control = OpenLayers.Class", you should get one
>> >> occurence of this, otherwise your build isn't valid, for some reason.
>> >> Eric
>> >>  > I have been on another project so I am just getting around to
>> >> compressing my
>> >> > version of openlayers.  So I thought I would try the stable version
>> >> > first
>> >> > before adding my stuff into it.
>> >> > Here are my steps:
>> >> > 1.  Grabbed latest stable build.
>> >> > 2.  Switched to build directory.
>> >> > 3.  python ./build.py full.cfg
>> >> > 4.  Copied Openlayers.js (466 KB) to ..  (1 directory above lib, same
>> >> level
>> >> > as build, img, theme, tools)
>> >> > 5.  Moved SpericalMercator.html example to this directory also.
>> >> > 6.  Changed to point to
>> >> > <script src="OpenLayers.js"></script>
>> >> > 7.  Run and get the following error:
>> >> > Microsoft JScript runtime error:  'OpenLayers.Control' is null or not
>> an
>> >> > object.
>> >> > I also get this when I use what I used in 2.5 to compress and it does
>> >> > not
>> >> > work in 2.6.
>> >> > Does anybody have any idea what to do with this error?  I would
>> really
>> >> like
>> >> > to compress Openlayers.
>> >> > Thanks!
>> >> > Linda Rawson
>> > Linda Rawson
> Linda Rawson
Linda Rawson
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20080828/4ca11cde/attachment.html
