[OpenLayers-Users] GML, Point and Change the Size of the Circle...
Eric Lemoine eric.c2c at gmail.com
Sat Aug 30 03:14:18 EDT 2008
Hi.
MapFish includes a build script allowing to build a minimal,
application-specific, single-file compressed library. You can even
have the build script build a combined OL + MF library. However Ext
(provided in MapFish) has separate <script> tags in the html file.
Yes MapFish may be overkill in certain situations, when you don't need
any MapFish components, or if your code relies on a stripped down
version of Ext. This makes of thing that it'd be great to provide page
where the user can select MapFish components and get in return a
compressed js library with the minimal MF+OL+Ext code into it. Might
not be easy, but would make an interesting internship for example.
Cheers. Eric
2008/8/29, Kit Plummer <kitplummer at gmail.com>:
> For me, Mapfish is just overkill.  There isn't anything that Mapfish
> provided that would help me out...so I'm just hitting the OL API.
> On Aug 29, 2008, at 7:19 AM, Lehtonen, Mika wrote:
>> Thanks for the hint!
>> Mapfish really seems to be very interesting. Someone in the list was
>> asking about draggable (resizeble) map window. Here you are:
>> http://demo.mapfish.org/stable/examples/map/window.html
>> If this really works and is easy to implement, I would give it a try.
>> And for sure, I will.
>> - mika -
>> Yves Moisan kirjoitti:
>>>> I've only been
>>>> working with OpenLayers for about a week.  And, I'm integrating it
>>>> into ExtJS.
>>> "MapFish Client is a JavaScript framework based on OpenLayers for the
>>> mapping part, and on ExtJs for the GUI (widgets)
>>> part" (http://trac.mapfish.org/trac/mapfish)
>>> I guess that may be useful for your endeavours.
>>> Yves Moisan
>>> Users mailing list
>>> Users at openlayers.org
>>> http://openlayers.org/mailman/listinfo/user
>> Users mailing list
>> http://openlayers.org/mailman/listinfo/users
> Users mailing list
